802.11k and 802.11v seamless roaming provide seamless switching to the access point with optimal signal when moving between APs. Omada Mesh technology enables wireless connectivity between access points for extended range, making wireless deployments more flexible and convenient.
Superior Wi-Fi performance and long-range coverage
Dedicated high-power amplifier and professional antennas along with the 802.11ac Wave 2 MU-MIMO technology, ensure superior Wi-Fi performance and long-range coverage over 2.4GHz and 5GHz wireless bands. -
Seamless roaming
802.11k and 802.11v helps client select access point automatically with the best signal to facilitate seamless transitions when move. This allows streaming communication like VoIP and video conferences uninterrupted. -
Specially designed weatherproof enclosure for outdoor environment
Rated as IP65 during Ingress Protection testing, a resilient weatherproof enclosure protects the access points against harsh outdoor condition. -
Detachable antennas
EAP225-Outdoor is designed with 2 omni-directional detachable antennas, which means other antennas can also be attached for your specific demands.
- TP-Link EAP225-Outdoor - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External - outdoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 16
- Included Accessories
- PoE injector, pole mount, wall mounting kit
- Power Over Ethernet (PoE) Supported
- PoE
- 4.6 cm x 2.7 cm x 21.5 cm
- Ruggedized Design
- Outdoor
- 4.6 cm
- 2.7 cm
- 21.5 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Wi-Fi Rating
- AC1200
- Load balancing, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, pole mountable, weatherproof, rogue access point detection, Captive Portal, 802.1x authentication, Watch Dog Timer (WDT), Transmit Power Control (TPC), MU-MIMO technology, beamforming technology, scheduler, band steering, SSID to VLAN mapping, rate limit, Wireless Scheduler, VLAN management, Airtime Fairness
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna Qty
- 2
- 1 x 1000Base-T (PoE) - RJ-45
- FCC, RoHS
- PoE
- 10.5 watt
- -30 °C
- 70 °C
- 10 - 90% (non-condensing)
