TP LINK EAP110 300Mbps Wireless N Ceiling Mount Access Point
Quicklinx: B887WS00 Mfr#: EAP110
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11n, Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
16 left in stock
£30.80 ex VAT
£36.96 inc VAT
The TP-LINK's EAP110 business Access Point provides a flexible, easy-to-deploy, manageable and robust security business-class wireless network solution. Simple mounting design to easily mount to a wall or ceiling. WLAN configuration and management are simplified through centralized management software. EAP110 also features captive portal and auto RF management, making it ideal for the high-density, intensive demanding businesses environment, include campus, hotels, malls and offices.
Flexible Placement - Easy mounting design & PoE
The EAP110's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations. EAP110 supports Passive Power over Ethernet (Passive PoE) to make deployment effortless and flexible. Simple and Scalable Business Wi-Fi Management - EAP Controller Software
The EAP Controller Software represents a cost-effective 'centralized management' solution for wireless networks of both small and medium business sectors (SMB). The software enables administrators to manage hundreds of EAPs easily from any PC on the network. Includes such administrative features as centralized configuration, real-time monitoring, graphical analysis of network traffic and batch firmware updates.
Powerful and Intuitive Software
Free controller software, no additional hardware controller required
Easy-to-use, no special training necessary
Upload floor plans for a more Intuitive Wi-Fi management
Batch firmware update support for effective administration
Advanced security features including Captive Portal, Rogue AP Detection
Visual Network Monitoring
Intuitively view traffic on any individual AP on the network
Graphical activity of clients connected to the network
Visual analytics of overall network usage and traffic distribution
Efficient Guest Authentication - Captive Portal
Captive portal provides one convenient method of authentication for Wi-Fi guests. A captive portal requires users to perform certain actions before network access is allowed. The required action must be verified by an external portal server or customized database by the administrator, which can be simply viewing and agreeing to an acceptable use policy, or entering a user ID and password.
Robust Safety Strategy - Multiple Wi-Fi Security Measures
The EAP110 supports the enterprise class Wi-Fi security, including WPA/WPA2-enterprise encryption and 802.1X radius. In addition, Multi-SSID, Wireless Isolation, MAC Filtering and Rogue AP detection features help to decrease network security threats.
Applicable to Multi-user Environment - Designed for Enterprise Performance
With easy mounting design, PoE power supply, Centralized management software, Captive portal, enterprise class security, and Enterprise hardware, EAP110 is specially designed for the highest-density, most demanding enterprise environments, including schools, hotels, and enterprises.
  • Flexible placement
    The EAP's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations. EAP110 supports passive PoE to make deployment effortless and flexible.
  • Efficient guest authentication
  • Designed for business performance
    EAP110 is specially designed for the high-density, most demanding business environments, including schools, hotels, and enterprises.
  • Load balance
    Load balance ensures large numbers of users have smooth network experiences in large business networks.
  • Dustproof design
    Prevents dust from dropping onto the PCB through bypass louver, which ensures long-term, unhindered operation.
  • Quality of Service (QoS)
    It prioritizes data, voice, and video applications to ensure time-sensitive traffic takes priority over all other traffic.
TP-Link Omada EAP110 - radio access point - Wi-Fi
Radio access point
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Maximum number of configured SSIDs: 8
PoE injector, wall mounting kit
Microsoft Windows Vista / XP / 7 / 8
Power Over Ethernet (PoE) Supported
PoE
18.94 cm x 17.23 cm x 2.95 cm
Radio access point
18.94 cm
17.23 cm
2.95 cm
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, CLI
Frequency Band
2.4 GHz
Status Indicators
System
Syslog support, manageable, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
Gain Level
3 dBi
1 x 100Base-TX (PoE) - RJ-45
FCC, RoHS
PoE
External power adapter
7.7 Watt
Software Included
Drivers & Utilities
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: Ethernet
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: Fast Ethernet
Compatibility: PC
Antennas: 2
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
