Unlock Seamless Coverage By Smart Antennas, WiFi That is Adaptive to Your Unique Home
True Tri-Band Speed
All three WiFi bands work together to unleash your network’s total speeds up to 7,800 Mbps for up to 200 devices
8 Streams, Less Lag
4×4/HE160 4804 Mbps + 2×2/HE160 2402 Mbps + 2×2 574 Mbps
Whole Home WiFi 6
Cover up to 6,100 ft2 with next-gen seamless WiFi and make dead zones and buffering a thing of the past
Up to 2.5 Gbps Wired Connections
1× 2.5 Gbps port + 2× Gigabit port offer high-speed data transmissions.
Seamless AI-Driven Mesh
Unites your home under one name and password while delivering the best connections as you move room to room
TP-Link HomeShield
Keeps your home network safe with cutting-edge features for network and IoT protection
Setup Made Easier Than Ever
The Deco app walks you through setup step-by-step
Unlock seamless coverage by smart antennas
By using intelligent algorithms, Smart antennas auto-detect Deco units and adjust to the most optimal antenna pattern arrays. This way, with 2 smart antennas, Deco X95 creates the ideal network throughout your home. -
Powerful and exquisite
Combining Tri-band Wi-Fi with high-tech Wi-Fi 6, Deco X95 provides 8 simultaneous data streams to open up more bandwidth and help your devices operate at full speed. With 2 smart antennas and 4 high-gain antennas, it not only delivers boosted Wi-Fi signals to every corner of your home but also brings a sense of aesthetics. -
Ultra-fast Multi-Gig Internet connection with 2.5Gbps port
A 2.5 Gbps port and 2 Gigabit ports make full use of the Gigabit speeds from your local ISP. Breakthrough the 1G bottleneck and drive your devices to peak performance. Plug your PCs, smart TVs, or game consoles into the ports for blazing-fast wired connections. -
Coverage in all the right places
To blanket your entire home with Wi-Fi, Deco X95 units work together as a powerful mesh network to boost broader coverage for connections in every corner. It provides an extra 5 GHz band working exclusively as the strong backhaul between deco units. -
Deco fits any type of your house
Brick and cement. Floors and ceilings. Walls and hallways. All of them make it tough for Wi-Fi to travel across your home. Deco units work together to move Wi-Fi around the obstacles in your home and deliver complete coverage. -
Engineered for more devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance. -
Intelligent networking for a smarter home
Deco uses its custom algorithms to automate the connections on your network, ensuring the strongest possible signals at all times. -
Protect your network and everything on it
TP-Link's premium security services keep your home network safe with advanced features for network and IoT protection.
- TP-Link Deco X95 V1 - Wi-Fi system - Wi-Fi 6 - desktop
- Wi-Fi system - mesh
- Enclosure Type
- Desktop
- Wi-Fi System Components
- 2 routers
- Wi-Fi System Coverage
- Up to 6,100 sq.ft
- Data Link Protocol
- Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Data Transfer Rate
- 7800 Mbps
- Performance
- Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps , Maximum data rate (5 GHz): 4804 Mbps , Channel bandwidth: 160 MHz
- Capacity
- Connected devices: up to 200 , Streams: 8
- PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6
- Routing Protocol
- IGMP, static IP routing
- Intelligent Assistant
- Alexa
- Remote Management Protocol
- DHCP
- Auto-sensing per device, IGMP snooping, IPS, parental control, Access Point operational mode, DDos attack prevention, QoS, DHCP server, port forwarding, NAP, reset button, SPIF, dynamic IP mode, FOTA, tagged VLAN, IGMP proxy, beamforming technology, Tri-Band, router mode, Backhaul Technology, 4x4 MU-MIMO technology, smart aerial, IPTV support, BSS Coloring, Guest Network, TP-Link HomeShield, Address Reservation, Real-Time IoT Protection, Malicious Site Blocker, Home Network Scanner, network access control, AI-Driven Mesh
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, UPnP, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Wi-Fi CERTIFIED 6
- Power
- AC 100-240 V (50/60 Hz) 0.8 A
- 13 cm x 12.3 cm x 21.05 cm
- 3-year warranty
- Wi-Fi system - mesh - 3-port switch (integrated)
- 2 routers
- Up to 6,100 sq.ft
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 7800 Mbps
- Performance
- Capacity
- Routing Protocol
- DHCP
- Encryption Algorithm
- WPA3-Personal, WPA2-Personal, WPA-Personal
- Wi-Fi Rating
- AX7800
- Mesh Networking
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, UPnP, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Wi-Fi CERTIFIED 6, IC, FCC, RoHS
- Processor
- 1.7 GHz
- Status Indicators
- Status
Line Properties
- Line Coding Format
- 1024 QAM, OFDMA
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- WAN / LAN: 1 x 2.5GBase-T - RJ-45 , WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 6
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- Electric Current Required
- 0.8 A
- 27 Watt
- Cables Included
- 1 x network cable
- 13 cm
- 12.3 cm
- 21.05 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% RH
