TP LINK Deco X60 Whole Home WiFi System - 3-pack
Quicklinx: H3X4WS00 Mfr#: Deco X60(3-pack)
Type: Wi-Fi system
Connectivity: Wired, Wireless
Speed: 5400Mbps
Protocol: Ethernet, IEEE 802.11ac, IEEE 802.11b, Gigabit Ethernet + 5 more
Compatibility: Android, Apple iOS
  • IEEE 802.11n
20 left in stock
£266.66 ex VAT
£319.99 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
Eliminate weak signal areas with a clearer, stronger whole home Wi-Fi signal generated from Wi-Fi 6. No more searching around for a stable connection.
Faster Connections:
Wi-Fi 6 speeds up to 5,400 Mbps—4,804 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
Connect More Devices:
OFDMA and MU-MIMO technology quadruple capacity to enable simultaneous transmission to more devices.
Boosted Seamless Coverage:
Achieve seamless whole-home coverage with a clearer and stronger whole-home Wi-Fi signal generated by Wi-Fi 6.
Ultra-Low Latency:
Greater reduction in latency enables more responsive gaming and video chatting.
One Unified Network:
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
Total Security:
WPA3 encryption and TP-Link HomeShield provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience.
TP-Link HomeShield:
Keeps your home network safe with cutting-edge features for network and IoT protection
Setup Made Easier Than Ever:
The Deco app walks you through the setup step-by-step.
  • Robust parental controls
    Manage content and control when each device can access the internet.
  • Built-in antivirus
    Protect all connected devices in your home from viruses and malware.
  • Assisted setup
    Easily set up Decos and find the ideal spot to place each unit.
  • Security
    Safeguard your home network with a firewall and wireless encryption.
TP-Link Deco X60 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps
Network / Transport Protocol
PPPoE, DHCP
Routing Protocol
Static IP routing
IPv6 support, parental control, Access Point operational mode, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, DHCP client, MU-MIMO technology, anti-virus protection, beamforming technology, band steering, TP-Link Adaptive Routing Technology, guest access, seamless roaming, black list
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax
11 cm x 11 cm x 11.4 cm
3.03 kg
Android 4.4 (KitKat) or later, Apple iOS 9 or later
3-year warranty
Wi-Fi system
3 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
PPPoE, DHCP
Routing Protocol
Static IP routing
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA3
Wi-Fi Rating
AX3000
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, VCCI, BSMI, IC, FCC, RoHS, KC, NCC, iDA, RCM, JRF, JPA
Qualcomm 1 GHz
Line Properties
Line Coding Format
1024 QAM, OFDMA
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
Installed Qty
3
1 x network cable
11 cm
11 cm
11.4 cm
3.03 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Connectivity: Wireless
Speed: 5400Mbps
Protocol: Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Fast Ethernet
Protocol: IEEE 802.11ax (Wi-Fi 6)
Compatibility: Apple iOS
Antennas: 4
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
