TP LINK Deco X60 Whole Home WiFi System - 2 - Pack
Quicklinx: GD5BWS00 Mfr#: DECO X60(2 Pack)
Type: Wi-Fi system
Connectivity: Wireless, Wired
Speed: 2402Mbps
Protocol: IEEE 802.11g, IEEE 802.11n, Ethernet, IEEE 802.11a + 5 more
Compatibility: Android, Apple iOS
  • IEEE 802.11n
11 In Stock
£249.99 ex VAT
£299.98 inc VAT
Eliminate weak signal areas with a clearer, stronger whole home Wi-Fi signal generated from Wi-Fi 6. No more searching around for a stable connection.
Faster Connections
Wi-Fi 6 speeds up to 3,000 Mbps—2,402 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
Connect More Devices
OFDMA and MU-MIMO technology quadruple capacity to enable simultaneous transmission to more devices . Boosted Seamless Coverage
Achieve seamless whole-home coverage with a clearer and stronger whole-home Wi-Fi signal generated by Wi-Fi 6.
Ultra-Low Latency
Greater reduction in latency enables more responsive gaming and video chatting.
One Unified Network
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
*Total Security
WPA3 encryption and TP-Link HomeShield provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience.
TP-Link HomeShield
Keeps your home network safe with cutting-edge features for network and IoT protection
Setup Made Easier Than Ever
The Deco app walks you through the setup step-by-step.
  • Robust parental controls
    Manage content and control when each device can access the internet.
  • Built-in antivirus
    Protect all connected devices in your home from viruses and malware.
  • Assisted setup
    Easily set up Decos and find the ideal spot to place each unit.
  • Security
    Safeguard your home network with a firewall and wireless encryption.
TP-Link Deco X60 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6
Routing Protocol
Static IP routing
Content filtering, manageable, IPv6 support, IPS, parental control, Access Point operational mode, firmware upgradable, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, MU-MIMO technology, anti-virus protection, beamforming technology, router mode, guest access, seamless roaming, black list
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax
11 cm x 11 cm x 11.4 cm
590 g
Android 4.4 (KitKat) or later, Apple iOS 9 or later
Wi-Fi system - mesh
2 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Static IP routing
Encryption Algorithm
WPA, WPA2-PSK, WPA3
Wi-Fi Rating
AX3000
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, VCCI, IC, FCC, RoHS, RCM, JRF, JPA
Qualcomm 1 GHz
RAM
4 GB SDRAM
Flash Memory
1 GB
Line Properties
Line Coding Format
1024 QAM, OFDMA
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
Directivity
Omni-directional
External power adapter
Installed Qty
2
24.5 Watt
1 x network cable
11 cm
11 cm
11.4 cm
590 g
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Speed: 2402Mbps
Protocol: IEEE 802.11n
Protocol: Ethernet
Protocol: IEEE 802.11a
Protocol: Fast Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ax (Wi-Fi 6)
Compatibility: Apple iOS
Antennas: 4
Brand: TP LINK
