TP LINK Deco X20 Whole Home WiFi System - 3-pack
Quicklinx: H3X2WS00 Mfr#: Deco X20(3-pack)
Type: Wi-Fi system
Connectivity: Wireless, Wired
Speed: 1800Mbps
Protocol: IEEE 802.11n, Ethernet, IEEE 802.11a, Fast Ethernet + 5 more
Compatibility: Android, Apple iOS
  • IEEE 802.11n
£149.99 ex VAT
£179.98 inc VAT
Armed with Wi-Fi 6 technology, Deco whole home mesh Wi-Fi is designed to deliver a huge boost in coverage, speed, and total capacity. Get on the mesh Wi-Fi to enjoy the future network that loads faster and connects more.
Faster Connections:
Wi-Fi 6 speeds up to 1,800 Mbps—1,201 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
Connect More Devices:
OFDMA and MU-MIMO technology quadruple capacity to enable simultaneous transmission to more devices.
Boosted Seamless Coverage:
Achieve seamless whole home coverage with a clearer and stronger whole home Wi-Fi signal generated by Wi-Fi 6.
Ultra-Low Latency:
Greater reduction in latency enables more responsive gaming and video chatting.
One Unified Network:
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
Total Security:
WPA3 encryption and TP-Link HomeShield provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience. Setup Made Easier Than Ever: The Deco app walks you through setup step-by-step.
AI-Driven Mesh: Always Learning, Constantly Optimizing
Armed with AI-Driven Mesh, Deco X20 delivers smart WiFi that follows you wherever you are, without interruption. It automatically learns your network environment, client quality, and user behaviors. Sophisticated algorithms account for various factors so that Deco X20 provides ideal mesh WiFi, unique to your home. Walk through your home and enjoy seamless streaming at the fastest possible speeds.
Engineered for More Devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance.
Greatly Reduced Lag, More Fun
Wi-Fi 6 brings stable and responsive Wi-Fi connections to tomorrow's hyper-connected home. Enjoy more responsive gaming and seamless video chatting even when multiple compatible devices are connected and transmitting data at the same time
Setup Just Got a Lot Easier
Unbox Deco, install the app and then simply follow the on-screen directions. Deco app will take care of the rest, getting your network up and running in minutes.
  • True seamless roaming for greater experiences
    TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
  • More connections for immersive streaming
    Enjoy a more efficient network with 4x the average throughput on connected devices in dense environments thanks to Wi-Fi 6 technology. Deco X20 is tested to connect over 150 devices without dragging down performance.
  • Greatly reduced lag, more fun
    Wi-Fi 6 brings stable and responsive Wi-Fi connections to tomorrow's hyper-connected home. Enjoy more responsive gaming and seamless video chatting even when multiple compatible devices are connected and transmitting data at the same time.
TP-Link Deco X20 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Network / Transport Protocol
PPPoE, DHCP
Routing Protocol
Static IP routing
IPv6 support, parental control, Access Point operational mode, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, DHCP client, MU-MIMO technology, anti-virus protection, beamforming technology, band steering, TP-Link Adaptive Routing Technology, guest access, seamless roaming, black list
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax
11 cm x 11 cm x 11.4 cm
2.66 kg
Android 4.4 (KitKat) or later, Apple iOS 9 or later
3-year warranty
Wi-Fi system
3 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
PPPoE, DHCP
Routing Protocol
Static IP routing
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA3
Wi-Fi Rating
AX1800
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, VCCI, BSMI, IC, FCC, RoHS, KC, NCC, iDA, RCM, JRF, JPA
Qualcomm 1 GHz
Line Properties
Line Coding Format
1024 QAM, OFDMA
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
Installed Qty
3
1 x network cable
11 cm
11 cm
11.4 cm
2.66 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Speed: 1800Mbps
Protocol: Ethernet
Protocol: IEEE 802.11a
Protocol: Fast Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ax (Wi-Fi 6)
Compatibility: Apple iOS
Antennas: 4
Brand: TP LINK
