TP LINK Deco X20 Whole Home WiFi Syetem - 2-pack
Quicklinx: H3X7WS00 Mfr#: Deco X20(2-pack)
Type: Wi-Fi system
Connectivity: Wireless, Wired
Speed: 1800Mbps
Protocol: Fast Ethernet, IEEE 802.11ac, Gigabit Ethernet, Ethernet + 5 more
Compatibility: Android, Apple iOS
  • IEEE 802.11n
£133.33 ex VAT
£159.99 inc VAT
Faster Connections:
Wi-Fi 6 speeds up to 1,800 Mbps—1,201 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
Connect More Devices:
OFDMA and MU-MIMO technology quadruple capacity to enable simultaneous transmission to more devices.
Boosted Seamless Coverage:
Achieve seamless whole home coverage with a clearer and stronger whole home Wi-Fi signal generated by Wi-Fi 6.
Ultra-Low Latency:
Greater reduction in latency enables more responsive gaming and video chatting.
One Unified Network:
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
Total Security:
WPA3 encryption and TP-Link HomeShield provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience. Setup Made Easier Than Ever: The Deco app walks you through setup step-by-step.
AI-Driven Mesh: Always Learning, Constantly Optimizing
Armed with AI-Driven Mesh, Deco X20 delivers smart WiFi that follows you wherever you are, without interruption. It automatically learns your network environment, client quality, and user behaviors. Sophisticated algorithms account for various factors so that Deco X20 provides ideal mesh WiFi, unique to your home. Walk through your home and enjoy seamless streaming at the fastest possible speeds.
Engineered for More Devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance.
Greatly Reduced Lag, More Fun
Wi-Fi 6 brings stable and responsive Wi-Fi connections to tomorrow's hyper-connected home. Enjoy more responsive gaming and seamless video chatting even when multiple compatible devices are connected and transmitting data at the same time
Setup Just Got a Lot Easier
Unbox Deco, install the app and then simply follow the on-screen directions. Deco app will take care of the rest, getting your network up and running in minutes.
  • Faster connections
    Wi-Fi 6 speeds up to 1,800 Mbps - 1,201 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
  • Connect more devices
  • Boosted seamless coverage
  • Ultra-low latency
  • One unified network
  • Total security
    WPA3 encryption and TP-Link HomeCare provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience.
  • Setup made easier than ever
TP-Link Deco X20 V2 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
Wi-Fi System Coverage
Up to 370 sq.m
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Network / Transport Protocol
PPPoE, DHCP, IPv4, IPv6
Routing Protocol
Static IP routing
Intelligent Assistant
Alexa
Remote Management Protocol
DHCP, IPv4, IPv6
Antivirus analysis, parental control, Access Point operational mode, WMM support, ACL support, QoS, DHCP server, port forwarding, reset button, SPIF, dynamic IP mode, DHCP client, MU-MIMO technology, beamforming technology, band steering, seamless roaming
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
11 cm x 11 cm x 11.4 cm
1.17 kg
Android 4.4 (KitKat) or later, Apple iOS 9 or later
Wi-Fi system - mesh
2 routers
Up to 370 sq.m
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Static IP routing
DHCP, IPv4, IPv6
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA3
Wi-Fi Rating
AX1800
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, VCCI, BSMI, IC, FCC, RoHS, KC, NCC, iDA, RCM, JRF, JPA
Qualcomm 1 GHz
Line Properties
Line Coding Format
1024 QAM, OFDMA
Internet of Things (IoT)
Alexa
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
Installed Qty
2
1 x network cable
Software Included
TP-Link HomeCare
11 cm
11 cm
11.4 cm
1.17 kg
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Speed: 1800Mbps
Protocol: IEEE 802.11ac
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Protocol: IEEE 802.11ax (Wi-Fi 6)
Compatibility: Apple iOS
Antennas: 8
Brand: TP LINK
