TP LINK Deco P9 Whole Home WiFi System - 3-pack
Quicklinx: H3X1WS00 Mfr#: Deco P9(3-pack)
Type: Wi-Fi system
Connectivity: Wired, Wireless
Speed: 1167Mbps
Protocol: Ethernet, IEEE 802.11g, IEEE 802.11n, Fast Ethernet + 5 more
Compatibility: [N/A]
  • IEEE 802.11n
£166.66 ex VAT
£199.99 inc VAT
Deco P9 combines dual-band Wi-Fi and powerline to establish a stronger mesh network. Powerline technology uses your home's electrical wiring to create stronger connections between Deco units, reducing the impact of walls and other obstacles on signal and providing even faster network speeds and truly seamless coverage.
The hybrid whole-home system delivers extended coverage up to 6,000 ft2/560 m2 with the help of the combination of dual-band Wi-Fi and powerline. Eliminate weak signal areas with whole-home Wi-Fi and no more searching around for a stable connection.
TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
Dual-Band Wi-Fi + Powerline - AC1200 dual-band Wi-Fi + AV1000 powerline combines for speeds of up to 2200 Mbps
Signal Works through Walls - Transmit data using your home’s electrical wiring, no worries about Wi-Fi dragging down by walls or ceilings.
Connect More Devices - Deco handles traffic from even the busiest network, providing lag-free connections up to 100 devices.
Seamless Roaming - Deco units work together to form a unified network. Walk through your home and stay connected with the fastest possible speeds.
MU-MIMO Technology - Simultaneously transfers data to multiple devices for faster performance.
Quality of Service - Prioritize devices for faster performance when needed.
Robust Parental Controls - Manage content and control when each device can access the internet.
Setup Made Easier than Ever - The Deco app walks you through setup step by step.
Great Compatibility - All Decos work together.
  • Mesh Wi-Fi + powerline: signal through walls
  • Dead-zone killer
  • Seamless roaming with one Wi-Fi name
TP-Link Deco P9 - Wi-Fi system - Wi-Fi 5, Bluetooth - desktop
Wi-Fi system
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
Wi-Fi System Coverage
Up to 6,000 sq.ft
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1167 Mbps
Network / Transport Protocol
PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
IPv6 support, parental control, Access Point operational mode, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, dynamic IP mode, DHCP client, anti-virus protection, router mode, TP-Link Adaptive Routing Technology
9.07 cm x 9.07 cm x 19 cm
Android 4.3 or later, Apple iOS 8.0 or higher
3-year warranty
Wi-Fi system
3 routers
Up to 6,000 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1167 Mbps
PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
Encryption Algorithm
WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1300
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, VCCI, BSMI, FCC, RoHS, KC, NCC, iDA, RCM, JRF, JPA
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
Installed Qty
3
1 x network cable
9.07 cm
9.07 cm
19 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Connectivity: Wireless
Speed: 1167Mbps
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Bluetooth 4.2
Antennas: 4
Brand: TP LINK
