TP LINK Day/Night Cloud Camera  300Mbps Wi-Fi
Quicklinx: BLYNWS00 Mfr#: NC220
Day/Night Cloud Camera, 300Mbps Wi-Fi
  • Night Vision - Automatic night vision functionality supports 24-hour surveillance
  • Advanced H.264 Video - For amazingly smooth video streaming
  • tpCamera App - Use the tpCamera app to access feeds from anywhere, at any time
  • Motion & Sound Detection - Immediate notification by email whenever motion or sound is detected
  • Easy Setup - Install and operate the camera within minutes
  • 300Mbps Wireless - 300Mbps wireless for fluid video and Wi-Fi extension
STAY CONNECTED AND SECURE
TP-LINK's NC220 is your perfect home and office companion, to help you keep in touch with what matters most, providing you with that sense of well-being while you are at work or play.
ANYWHERE, ANYTIME ACCESS WITH TPCAMERA APP
With the tpCamera app for your smartphone, you can record videos, take pictures or just check up on what's happening wherever there is Internet. Whether you are at the office or at play, you'll never miss those special moments. NC220 helps you always be there, even when you are not.
PEACE OF MIND THROUGH THE NIGHT
Equipped with Night Vision function, the NC220 enables you to view up to 18 feet, even in complete darkness, giving you great peace of mind.
STAY ALERT WITH MOTION & SOUND DETECTION AND INSTANT EMAIL
The NC220 can be set up to send immediate notification by email whenever motion or sound is detected automatically, allowing you to remain aware of whatever's happening on the ground.
A STRAIGHT FORWARD SETUP AND FLEXIBLE DEPLOYMENT
Set Up In Minutes
The set up is so simple and user friendly, that anyone can install and operate the camera within minutes, and WPS support means that if you have a router with WPS button, you can complete the setup wirelessly. The tpCamera App also guides you through all the configurations and settings. It's child's play.
Adaptable Placement
With the sticky pad or screws, you can place your NC220 anywhere you want, on the table, the wall, or even on the ceiling.
300MBPS WIRELESS - FOR FLUID VIDEO & WI-FI EXPANSION
With a stable high speed Wi-Fi connection of up to 300Mbps, you can enjoy fluid video streaming with ease. In addition, the NC220 can also expand your Wi-Fi network with its Wi-Fi Extender functionality.
  • Stay connected and secure
  • Peace of mind through the night
    Equipped with Night Vision function, the NC220 can work even in complete darkness, giving you great peace of mind.
  • Stay alert with motion and sound detection
    The NC220 can be set up to send immediate notification by e-mail whenever motion or sound is detected automatically, allowing you to remain aware of whatever's happening on the ground.
  • Setup in minutes
    The setup is so simple and user-friendly, that anyone can install and operate the camera within minutes, and WPS support means that if you have a router with WPS button, you can complete the setup wirelessly.
  • Adaptable placement
    You can place your NC220 anywhere you want, on the table, the wall, or even on the ceiling.
  • High-speed wireless for fluid video & Wi-Fi expansion
    With a stable high-speed Wi-Fi connection, you can enjoy fluid video streaming with ease. In addition, the NC220 can also expand your Wi-Fi network with its Wi-Fi Extender functionality.
TP-Link NC220 - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
6.1 cm x 2.4 cm x 9.6 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Frame Rate (max)
20 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/4" - 0.3 MP
Minimum Illumination
0.5 lux
Focal Length
3.85 mm
Lens Iris
F/2.8
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 9 V
Date/time stamp, saturation control, contrast control, image flip, image mirror, Motion Detection Technology, Sound Detection Sensor, Wi-Fi Protected Setup (WPS), text stamp, notification picture to E-mail, notification picture to FTP, password protection
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
6.1 cm
2.4 cm
9.6 cm
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
640 x 480
Motion Detection
Digital Zoom
4
0.5 lux
Video Capture
640 x 480 @ 20 fps , 320 x 240 @ 20 fps
Image Sensor
0.3 MP CMOS 1/4"
Lens Construction
Focal Length
3.85 mm
Lens Iris
F/2.8
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTPS, UPnP, Bonjour, PPPoE, Samba
Ports
LAN - RJ-45
1 x network cable - external
FCC, RoHS
Power Requirements
DC 9 V
Power adapter - external
Apple MacOS X 10.7 or later, Microsoft Windows Vista / XP / 7 / 8
Relative Humidity (operating)
BLYN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
BLYN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.84
