TP LINK CPE605 5GHz N150 Outdoor CPE
Quicklinx: FT8FWS00 Mfr#: CPE605
Type: Radio access point
Connectivity: Wireless
Speed: 150Mbps
Protocol: IEEE 802.11a, IEEE 802.11n
Compatibility: [N/A]
  • IEEE 802.11n
£42.33 ex VAT
£50.79 inc VAT
With 23dBi high-gain directional Cassegrain antenna and dedicated metal reflector, the CPE605 provides excellent beam directivity, improved latency and noise immunity. Professional performance, coupled with user-friendly design, makes the 5GHz 150Mbps 23dBi Outdoor CPE605 an ideal choice and cost-effective solution for outdoor wireless networking applications.
  • Compact and lightweight packaging
    Small and lightweight boxes benefit shipping, logistics and retail.
  • Pharos Control - centralized management system
    CPE605 comes equipped with Pharos Control centralized management software, helping users easily manage all devices in their network from a single PC. Functions include device discovery, status monitoring, firmware upgrading, and network maintenance. An intuitive web-based interface-PharOS-provides an alternative management method, and allows professionals to access more detailed configurations.
TP-Link CPE605 - radio access point - Wi-Fi
Radio access point
External - outdoor
1 x Qualcomm MIPS 74KC 560 MHz
RAM
64 MB
Flash Memory
8 MB
Frequency Band
5 GHz
PoE injector, pole mount
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7/8/10
Power Over Ethernet (PoE) Supported
PoE
35 cm x 25.5 cm x 20.7 cm
Radio access point
Ruggedized Design
Outdoor
35 cm
25.5 cm
20.7 cm
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
64 MB DDR2 SDRAM
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 2c, HTTP, HTTPS, SSH, DHCP
Frequency Band
5 GHz
Firewall protection, DHCP support, power over Ethernet (PoE), Syslog support, ALG support, MAC address filtering, Wireless Distribution System (WDS) support, Access Point operational mode, 15 KV Electrostatic Discharge Protection, virtual server support, Multiple SSID support, reset button, bandwidth control, port triggering, weatherproof, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, SNMP support, Time Division Multiple Access (TDMA), Dynamic Frequency Selection (DFS), SSID to VLAN tagging, Denial of Service (DoS) protection, dustproof, waterproof, L2TP support, 6KV lightning protection
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
Secure Shell (SSH)
IEEE 802.11a, IEEE 802.11n, UPnP
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Directional
Gain Level
23 dBi
1 x 100Base-TX (PoE) - RJ-45
FCC, RoHS, IP65
PoE
Power injector
-40 °C
70 °C
10 - 90% (non-condensing)
Speed: 150Mbps
Protocol: IEEE 802.11n
Antennas: 1
Brand: TP LINK
