TP LINK CPE510 Pharos Outdoor 5Ghz 13dBi Wireless-N Access Point
Quicklinx: 9PMWWS00 Mfr#: CPE510
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11a, IEEE 802.11n
Compatibility: Mac, PC, Unix
  • IEEE 802.11n
£41.14 ex VAT
£49.36 inc VAT
The TP-LINK CPE510 Pharos Outdoor 5Ghz 13dBi Wireless-N Access Point is part of the Pharos CPE range that is dedicated to cost effective solutions for outdoor wireless networking applications. With its centralised management application, it is ideal for point-to-point, point-to-multipoint and outdoor Wi-Fi coverage applications. Professional performance, coupled with user-friendly design, makes this TP-LINK CPE510 an ideal choice for both business and home users.
Pharos Control - Centralised Management System
This TP-LINK CPE510 also comes equipped with centralised management software that helps users easily manage all the devices in their network from a single PC - Pharos Control. Functions like device discovery, status monitoring, firmware upgrading, and network maintenance can be managed using Pharos Control.
Enterprise Hardware Design
With Qualcomm Atheros enterprise level chipsets, high gain antennas and high quality material, specially designed enclosure, and PoE power supply, a TP-LINK CPE510 is specially designed for outdoor use and can operate flawlessly in almost any climate, with operating temperatures ranging from -30C (-22F) to +70C (158F).
Advanced Antenna System
Built-in High Gain Dual-Polarized 13dBi Antenna and dedicated metal reflection ensures higher gain and lower noise interference.
High Power and High Sensitivity
In advanced, high power Tx (up to 27dBm/500mw) and high sensitivity Rx (up to -95dBm) radio front-end design breaks down the barriers of traditional Wi-Fi transmission range, making the TP-LINK CPE510 an ideal product for outdoor wireless networking applications.
Weatherproof Design
With its outdoor weatherproof enclosure and industrial-level hardware design, the TP-LINK CPE510 can continue operating in various weather conditions, such as sunshine, rainfall, wind, snow or extremely low/high temperature environment(-30C~70C).
Double Protection against ESD Attacks
Besides its grounding terminal, the TP-LINK CPE510 offers another way to eliminate ESD attacks via the PoE adapter and Ethernet cable with grounding wire. The TP-LINK CPE510's additional security measures provide up to 15KV ESD and 6000V lightning protection for more reliable operation.
TP-LINK MAXtream TDMA Technology
As network scale increases, wireless competition and collisions among CPEs and base stations will be so enormous that the real throughput of the network will drop, resulting in a serious impact on end-user experience, to mitigate these effects, the TP-LINK CPE510 uses MAXtream TDMA Technology.
Built-in 13dBi 2x2 dual-polarized directional MIMO antenna using 5GHz band
Adjustable transmission power from 0 to 27dBm/500mw
System-level optimisations for more than 15km long range wireless transmission
TP-LINK Pharos MAXtream TDMA (Time-Division-Multiple-Access) technology
AP / Client / Repeater / AP Router / AP Client Router (WISP) operation modes
Centralised Management System - Pharos Control
Passive PoE Adapter supports up to 60 meter (200 feet)
Standard Warranty: 3-Years
  • Enterprise hardware
    With Qualcomm Atheros enterprise level chipsets, high gain antennas and high quality material, specially designed enclosure, and PoE power supply, CPE510 is specially designed for outdoor use and can operate flawlessly in almost any climate, with a wide range of operating temperatures.
  • 15km+ wireless data transmission
    Specially designed for outdoor uses, ideal for long distance wireless data transmission over 15km+, tested in the field.
  • TP-LINK MAXtream TDMA technology
    As network scale increases, wireless competition and collisions among CPEs and base stations will be so enormous that the real throughput of the network will drop, resulting in a serious impact on end-user experience. To mitigate these effects, the CPE510 uses MAXtream TDMA technology.
  • Pharos Control - centralized management system
    CPE510 also comes equipped with centralized management software that helps users easily manage all the devices in their network from a single PC - Pharos Control. Functions like device discovery, status monitoring, firmware upgrading, and network maintenance can be managed using Pharos Control.
  • PharOS
    User-friendly web-based management system allows professionals to do more specific configurations.
TP-Link CPE510 - radio access point - Wi-Fi
Radio access point
External
RAM
64 MB
Flash Memory
8 MB
Frequency Band
5 GHz
PoE injector, pole mount
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7/8
Power Over Ethernet (PoE) Supported
PoE
7.9 cm x 6 cm x 22.4 cm
Radio access point
7.9 cm
6 cm
22.4 cm
Processor / Memory / Storage
RAM
64 MB DDR2 SDRAM
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
5 GHz
Routing, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), repeating mode, MIMO technology, 15 KV Electrostatic Discharge Protection, WISP mode, wireless bridge mode, Wireless Client Mode, weatherproof
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Directional
Gain Level
13 dBi
1 x 100Base-TX - RJ-45
FCC, RoHS, IPX5
PoE
11 watt
-30 °C
70 °C
10 - 90% (non-condensing)
9PMW C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
9PMW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
Speed: 300Mbps
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Antennas: 1
Brand: TP LINK
