TP LINK CPE210 2.4GHz 300Mbps 9dBi Outdoor Access Point
Quicklinx: 9XF9WS00 Mfr#: CPE210
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11g, IEEE 802.11n, IEEE 802.11b
Compatibility: Mac, PC, Unix
  • IEEE 802.11n
More than 50 In Stock
£32.04 ex VAT
£38.44 inc VAT
TP-LINK's 2.4GHz 300Mbps 9dBi Outdoor CPE, the CPE210 is dedicated to cost effective solutions for outdoor wireless networking applications. With its centralized management application, it is ideal for point-to-point, point-to-multipoint and outdoor Wi-Fi coverage applications. Professional performance, coupled with user-friendly design, makes CPE210 an ideal choice for both business and home users.
Enterprise Hardware Design
With Qualcomm Atheros enterprise level chipsets, high gain antennas and high quality material, specially designed enclosure, and PoE power supply, CPE210 is specially designed for outdoor use and can operate flawlessly in almost any climate, with operating temperatures ranging from -30 (-22) to +70 (158).
Advanced Antenna System
Built-in High Gain Dual-Polarized Antenna and dedicated metal reflection ensures higher gain and lower noise interference.
High Power & High Sensitivity
In advanced, high power Tx (up to 27dBm/500mw) and high sensitivity Rx (up to -95dBm) radio front-end design breaks down the barriers of traditional Wi-Fi transmission range, making CPE210 an ideal product for outdoor wireless networking applications.
Professional Outdoor Design
CPE210 is designed to work in harsh environments, even in some of the world's most hostile climate conditions.
Weatherproof Design
With its outdoor weatherproof enclosure and industrial-level hardware design, CPE210 can continue operating in various weather conditions, such as sunshine, rainfall, wind, snow or extremely low/high temperature environment(-30 degrees to 70 degrees).
Double Protection against ESD AttacksBesides its grounding terminal, CPE210 offers another way to eliminate ESD attacks via the PoE adapter and Ethernet cable with grounding wire. The CPE210's additional security measures provide up to 15KV ESD and 6000V lightning protection for more reliable operation.
TP-LINK MAXtream TDMA Technology
As network scale increases, wireless competition and collisions among CPEs and base stations will be so enormous that the real throughput of the network will drop, resulting in a serious impact on end-user experience, to mitigate these effects, the CPE210 uses MAXtream TDMA Technology.
5km+ Wireless Data Transmission
Specially designed for outdoor uses, ideal for long distance wireless data transmission over 5km+, tested in the field.
Pharos Control - Centralized Management System
CPE210 also comes equipped with centralized management software that helps users easily manage all the devices in their network from a single PC - Pharos Control. Functions like device discovery, status monitoring, firmware upgrading, and network maintenance can be managed using Pharos Control.
PharOS
User-friendly web-based management system allows professionals to apply more specific configurations
  • Enterprise hardware design
    With Qualcomm Atheros enterprise level chipsets, high gain antennas and high quality material, specially designed enclosure, and PoE power supply, CPE210 is specially designed for outdoor use and can operate flawlessly in almost any climate.
  • High power & sensitivity
    In advanced, high power Tx and high sensitivity Rx radio front-end design breaks down the barriers of traditional Wi-Fi transmission range, making CPE210 an ideal product for outdoor wireless networking applications.
  • Professional outdoor design
  • Weatherproof design
    With its outdoor weatherproof enclosure and industrial-level hardware design, CPE210 can continue operating in various weather conditions, such as sunshine, rainfall, wind, snow or extremely low / high temperature environment(-30°C~70°C).
  • TP-LINK MAXtream TDMA technology
  • 5km+ wireless data transmission
  • Pharos Control - centralized management system
  • PharOS
    User-friendly web-based management system allows professionals to apply more specific configurations.
Header / Brand
TP-LINK
Brand
TP-LINK
Networking / Connectivity Technology
Wireless
Radio access point
Header / Model
CPE210
Protocol
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Speed
300 Mbps
Networking / Form Factor
External
Dimensions & Weight / Depth
79 mm
Dimensions & Weight / Height
60 mm
Dimensions & Weight / Width
224 mm
Header / Packaged Quantity
1
Compatibility
PC, Mac, Unix
9XF9 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9XF9 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.76
9XF9 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9XF9 051399
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £26.02
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Speed: 300Mbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Antennas: [N/A]
Brand: TP LINK
Stock Status: Used Stock
