Wi-Fi 7 Routers
With powerful Wi-Fi 7 performance, lightning-fast wired connections, and brand-new design
Blazing-Fast 9214 Mbps Tri-Band wireless Router
Enables your devices to run at full speed; Enjoy fluent 4K/8K streaming, immersive AR/VR gaming, and blazing-fast downloads
Multi-Link Operation (MLO)
Increases throughput, reduces latency, and improves reliability for emerging applications
5× 2.5G Ports
1× 2.5 Gbps WAN port and 4× 2.5 Gbps LAN ports break through the 1G bottleneck, driving your devices to peak performance
Maximized Coverage
Proprietary Wi-Fi optimization and optimally positioned antennas along with Beamforming deliver more capacity, stronger and more reliable connections, and less interference
EasyMesh-Compatible
Works with EasyMesh routers and range extenders to form seamless whole home Mesh Wi-Fi, preventing drops and lag when moving between signals
Easy Setup and Use
Network management has never been easier with the Tether app
TP-Link HomeShield
Enhanced security defends against the latest cyber threats
Great Compatibility
Supports all Wi-Fi generations and devices**and all internet providers
Robust connectivity options
The Archer BE550 V2 provides multiple ports including four for WAN and LAN connections alongside a USB 3.0 port, enabling versatile connectivity for various devices and applications. -
Advanced security features
This wireless router includes several encryption protocols such as WPA3 and advanced parental control options to ensure a secure online environment for all connected devices. -
Wireless performance
With a maximum data transfer rate of 9214 Mbps and support for Wi-Fi standards, this device is designed to deliver high-speed Internet for streaming, gaming, and more. -
Smart home compatible
Compatible with popular voice assistants like Google Assistant and Alexa, the Archer BE550 V2 enhances home automation capabilities, allowing users to manage their network conveniently. -
Optimized for high-definition content
The router is capable of supporting 4K/8K UHD video streaming, making it perfect for households that enjoy high-definition media without interruptions.
- TP-Link Archer BE550 V2 - wireless router - Wi-Fi 7 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6E), IEEE 802.11be (Wi-Fi 7)
- Frequency Band
- 2.4 GHz / 5 GHz / 6 GHz
- Data Transfer Rate
- 9214 Mbps
- Performance
- Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2880 Mbps , Maximum data rate (6 GHz): 5760 Mbps , Channel bandwidth: up to 320 MHz , Aggregate data rate: 5 Gbps
- PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6, WireGuard, OpenVPN
- Routing Protocol
- IGMP, static IP routing
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Remote Management Protocol
- DHCP
- NAT support, IGMP snooping, parental control, Access Point operational mode, DDos attack prevention, ACL support, QoS, Samba support, FTP server, port forwarding, reset button, port triggering, SPIF, IP-MAC binding, tagged VLAN, VPN Server, IGMP proxy, 802.1x authentication, router mode, LED on/off button, seamless roaming, Airtime Fairness, Smart Roaming, DMZ support, DynDNS, bridge mode, OpenVPN server, IPTV support, WPS button, EasyMesh, 4K/8K UHD video streaming, Guest Network, TP-Link HomeShield, SIP ALG, Wi-Fi on/off button, Hassle Free, Real-Time IoT Protection, Malicious Site Blocker, Home Network Scanner, remote firmware upgrade, anti-jamming, PPTP VPN server, MLO, MRU, L2TP VPN server
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7
- 7.6 cm x 23.17 cm x 20.3 cm
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 9214 Mbps
- Performance
- Routing Protocol
- DHCP
- Encryption Algorithm
- WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
- Wi-Fi Rating
- BE9300
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7, FCC, RoHS
Line Properties
- Line Coding Format
- 4096 QAM, OFDMA
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Voice Controlled
- Indirect
- WAN: 1 x 2.5GBase-T - RJ-45 , LAN: 4 x 2.5GBase-T - RJ-45 , USB 3.0: 1 x
Aerial
- Aerial
- Internal
- Antenna Qty
- 6
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- 7.6 cm
- 23.17 cm
- 20.3 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J1R9 051310 Condition: Customer return - item has been opened but is in excellent condition |
£91.92 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
