TP LINK BE3600 Whole Home Mesh Wi-Fi 7 System(3-pack)
Quicklinx: J1R4WS00 Mfr#: Deco BE25(3-Pack)
  • IEEE 802.11n
Hurry, only 3 left in stock!
£270.83 ex VAT
£324.99 inc VAT
3.6 Gbps Dual-Band Mesh WiFi
2882 Mbps (5 GHz) + 688 Mbps (2.4 GHz)
2.5 Gbps Wired Connections
2x 2.5 Gbps ports ensure max flexibility and boosted throughput; always share the highest level of internet speed with high speed Deco wifi extender booster
Wireless and Wired Combined Backhaul
Connects a wireless and wired backhaul with each unit simultaneously to improve overall throughput and reduce latency; enjoy the speed with Deco wifi extender
Multi-Link Operation (MLO)
Simultaneously send and receive data across different bands and channels to increase throughput with Deco wifi repeater, reduce latency, and improve reliability
Seamless AI-Driven Roaming
Forms a unified wifi mesh system network with built-in AI-Roaming creating the ideal Wi-Fi solution for your home
TP-Link HomeShield
Provides comprehensive network protection, robust parental controls, and real-time IoT security; ensure the secure and fast internet with the Deco wifi booster
Universal Compatibility Wifi 7 Mesh
Backward compatible with all WiFi generations and works with any internet service provider (ISP) and modem
  • Advanced connectivity
    Equipped with Ethernet 2.5GBase-T interface and supporting both wired and wireless connections, the Deco BE25 V1 ensures high-speed Internet access for all your devices. Its dual WAN/LAN ports offer flexible network configuration options, catering to various user needs.
  • Comprehensive security
    Featuring WPA3-Personal encryption and a Stateful Packet Inspection Firewall (SPIF), the Deco BE25 V1 provides robust protection against unauthorized access and various online threats. TP-Link HomeShield further enhances network security with features like Real-Time IoT Protection, ensuring a safe online environment for your home.
  • Seamless Wi-Fi coverage
    With AI-Driven Mesh technology and support for Wi-Fi 6, the Deco BE25 V1 delivers extensive and seamless Wi-Fi coverage throughout your home. Its capability to connect up to 150 devices and support for multiple Wi-Fi bands ensures a reliable and efficient network.
  • Intelligent operation
    The Deco BE25 V1 is designed for smart homes, offering compatibility with Alexa and Google Assistant for voice-controlled convenience. Its intelligent features like parental control, guest network, and VPN support provide a customizable and secure networking experience.
  • High-performance networking
    Achieving data transfer rates of up to 3.6 Gbps and supporting channel bandwidth of 160 MHz, the Deco BE25 V1 is capable of handling demanding activities like HD streaming, online gaming, and large file transfers with ease.
TP-Link Deco BE25 V1 - Wi-Fi system - Wi-Fi 7 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6), IEEE 802.11be (Wi-Fi 7)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.6 Gbps
Performance
Maximum data rate (2.4 GHz): 688 Mbps , Maximum data rate (5 GHz): 2882 Mbps , Channel bandwidth: 160 MHz
Connected devices: up to 150 , Streams: 6
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS, IPv4, IPv6, OpenVPN
Routing Protocol
IGMP, static IP routing
Intelligent Assistant
Google Assistant, Alexa - indirect
Remote Management Protocol
DHCP
Auto-sensing per device, NAT support, IGMP snooping, parental control, Access Point operational mode, DDos attack prevention, ACL support, DHCP server, port forwarding, reset button, bandwidth control, SPIF, DHCP client, VPN Server, IGMP proxy, MU-MIMO technology, VPN client, router mode, Backhaul Technology, client isolation, VLAN Tagging, bridge mode, schedule reboot, IPTV support, WPS button, BSS Coloring, Guest Network, TP-Link HomeShield, Real-Time IoT Protection, Malicious Site Blocker, Home Network Scanner, AI-Driven Mesh, MLO, MRU
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, UPnP, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7
15 cm x 15 cm x 6.2 cm
Wi-Fi system - mesh - 2-port switch (integrated)
3 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.6 Gbps
Performance
Routing Protocol
DHCP
Encryption Algorithm
WPA3-Personal, WPA2-Personal, WPA-Personal
Wi-Fi Rating
BE3600
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, UPnP, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7, FCC, RoHS
Line Properties
Line Coding Format
4096 QAM, OFDMA
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Controlled
Indirect
WAN / LAN: 2 x 2.5GBase-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
Installed Qty
3
1 x network cable
15 cm
15 cm
6.2 cm
10 - 90% RH
Type: Wi-Fi system
Connectivity: Wired
Connectivity: Wireless
Speed: 3.6Gbps
Protocol: Ethernet
Protocol: IEEE 802.11a
Protocol: Fast Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ax (Wi-Fi 6)
Protocol: IEEE 802.11be (Wi-Fi 7)
Protocol: 2.5 Gigabit Ethernet
Brand: TP LINK
