12-Stream 22 Gbps Tri-Band WiFi Mesh
11520 Mbps (6 GHz) + 57600 Mbps (5 GHz) + 1376 Mbps (2.4 GHz)
Unprecedented 10 Gbps Mesh Network
1× 10 Gbps Ethernet/Fiber Combo WAN/LAN port + 1× 10 Gbps WAN/LAN port + 2?2.5 Gbps ports ensure max flexibility and boosted throughput
Multi-Link Operation (MLO)
Simultaneously send and receive data across different bands and channels to increase throughput, reduce latency, and improve reliability of your mesh wifi 7 system
320 MHz Channels Deco Mesh Technology
Double the bandwidth and enables many more simultaneous transmissions at the fastest possible speeds
Works on the 6 GHz Band
Minimizes congestion with greenfield spectrum, delivering robust high-speed connections
TP-Link HomeShield
Provides comprehensive network protection, robust parental controls, and real-time IoT security for your wifi mesh extender
Universal Compatibility
Backward compatible with all Wi-Fi generations and works with any internet service provider (ISP) and modem. With 3 years of manufacture warranty.
Compatible with New iPhone
The new iPhone 16 and 16 Pro now support the latest WiFi 7 standard, while TP-Link WiFi 7 Mesh delivers the speed and performance of this next-gen WiFi technology
Blazing-fast Wi-Fi for excellent performance
Experience a high-end tri-band whole-home Wi-Fi 7 Mesh system with blazing-fast Wi-Fi speeds up to 19 Gbps. Every device in your home network will run at top performance. The exclusive 6 GHz band provides exceptional bandwidth and congestion-free channels exclusive to your devices. -
Outstanding 10 Gbps wired performance
Equipped with two 10 Gbps WAN/LAN ports - one RJ-45 port and a RJ-45/SFP+ combo port - Deco BE85 provides flexible support for both fiber and copper connections. The additional 2.5 Gbps ports and USB 3.0 port make it an ideal solution for future-proofing your home network. -
Down to the last detail
TP-Link's in-house component research and thorough hardware selection ensure the quality and value of the entire Deco BE85 system. Everything comes together to form the perfect Mesh device. -
Stronger and more flexible
Through a self-developed technology, Deco BE85 can connect a wireless and wired backhaul with each unit simultaneously. What's more, with the Wi-Fi 7 MLO technology, the system's wireless and wired combined backhaul aggregation flow rate is increased. This way, it greatly improves overall throughput and reduces latency, delivering broader coverage with more stable and reliable connections. -
Smart security for smart living
HomeShield provides a series of built-in services that protect all your devices comprehensively with various features for when you're at home or on the go. With HomeShield, safer Internet experiences bring more happiness to your smart living. -
VPN clients and server supported
Allow devices in your home network to access remote VPN servers without needing to install VPN software on every device. You can create different VPN connection types, including OpenVPN, PPTP, L2TP/IPSec VPN. Besides, Deco can run both the VPN and ordinary Internet connections at the same time, delivering security and flexibility. -
Private IoT network for more security
Set up a separate Wi-Fi for IoT devices and overlay HomeShield and advanced WPA3 encryption to better protect the security of your home network and IoT devices. -
Uninterrupted streaming when moving between rooms
Deco Mesh forms a unified network with a single network name. With built-in AI-Roaming technology, it creates the ideal Wi-Fi solution with its advanced algorithms and self-learning. Walk through your home and enjoy seamless streaming at the fastest possible speeds.
