TP LINK AX3000 Multi-Gigabit Wi-Fi 6 Router
Quicklinx: H4YNWS00 Mfr#: Archer AX55 Pro
  • IEEE 802.11n
£76.66 ex VAT
£91.99 inc VAT
Marketing description is not available.
  • Incredible speed
    Drastically improved WiFi 6 speeds enable streaming, fast downloading, and gaming - all at the same time. 5 GHz with 160 MHz channel support doubles the bandwidth, enabling 8K video without lag.
  • Go faster - multi-gig wired connections
    In addition to stunning wireless speeds, AX55 Pro also provides premium wired connections. A 2.5 Gbps port and 1 Gbps port make full use of gigabit speeds from your local ISP. Break through the 1G bottleneck and drive your devices to peak performance. WAN/LAN support gives you remarkable flexibility to tailor both ports to fit your network's needs.
  • WiFi coverage throughout your home
    4× high-performance antennas boost WiFi signals throughout your home. Beamforming technology detects devices and concentrates signals towards them, especially to previously hard-to-reach areas.
  • Massively expanded device capacity
    Enjoy smooth gaming, video streaming, and live feeds simultaneously. OFDMA makes your WiFi stronger by allowing multiple clients to share one band at the same time, which cuts latency and jittering.
  • Improved cooling design for full output
    No heat ups, no throttles. A larger heat sink and refined case design cool the WiFi 6 system and enable your network to stay at top speed in more versatile environments.
  • Flexibly create whole home WiFi with Archer AX55 Pro
    Want to build a whole-home Wi-Fi? Archer AX55 Pro supports OneMesh to form seamless whole-home coverage, preventing drops and lag when moving between signals.
  • Advanced security for your everyday devices
    With TP-Link HomeShield, enjoy advanced security features delivering a safe environment that protects your family and network's data and privacy.
  • VPN clients and server supported
    Allow devices in your home network to access remote VPN servers without needing to install VPN software on every device. Archer AX55 Pro can run both the VPN and ordinary internet connections at the same time, delivering security and flexibility.
  • USB 3.0 ports
    Easily share files between connected devices by plugging into an external drive. You can even make it your personal cloud storage and access it from outside securely.
  • Easy setup and use
    Whether you prefer the intuitive Tether app or TP-Link's powerful web interface, you can set up your Archer AX55 Pro in minutes. The Tether app allows you to manage network settings from any Android or iOS device.
TP-Link Archer AX55 Pro V1 - wireless router - Wi-Fi 6 - desktop
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2042 Mbps
Routing Protocol
Static IP routing
NAT support, VPN support, SPI, parental control, ACL support, QoS, WPS, DHCP server, FTP server, port forwarding, UPnP Media Server, reset button, port triggering, dynamic IP mode, DHCP client, power-saving mode, beamforming technology, Smart Connect, Airtime Fairness, DMZ support, OpenVPN client, OpenVPN server, 8K HD video streaming, OneMesh support, Guest Network, TP-Link HomeShield
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
12 V 1.5 A
26.11 cm x 13.45 cm x 4.1 cm
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2042 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPS, WPA3
Wi-Fi Rating
AX3000
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, FCC, RoHS
Status Indicators
Status
Line Properties
Line Coding Format
OFDMA
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN / LAN: 1 x 1000Base-X - RJ-45
Aerial
Aerial
External
Antenna Qty
4
Directivity
Directional
External power adapter
12 V
Electric Current Required
1.5 A
1 x network cable
Software Included
Microsoft Internet Explorer 11, Safari 4.0+, Chrome 20.0+, Firefox 12.0+
26.11 cm
13.45 cm
4.1 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wireless router
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: Ethernet
Standards: Fast Ethernet
Standards: 802.11ax
Standards: IEEE 802.11ac
Speed: 2042Mbps
Brand: TP LINK
