Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
TP LINK AV600 Passthrough Powerline Kit
Quicklinx: FTN7WS00 Mfr#: TL-PA4022P KIT
Type: Powerline adapter kit
Speed: 600Mbps
Connectivity: Wired
Pass-through Socket: Yes
£47.85 ex VAT
£57.42 inc VAT
You need to connect your router in the living room with your desktop in the bedroom upstairs. Trailing a long Ethernet cable through the house isn't a good look, and it's expensive to install additional wiring in the walls. With powerline, there's a better way.
The TL-PA4022P KIT transforms your home's existing electrical circuit into a high speed network. No configuration is required - plug your adapter into a power socket and establish a connection within minutes.
  • Plug-and-play
    Ditch the complicated setup process for good. Get started with powerline in just two steps. Connect TL-PA4010P to your router and then plug in TL-PA4020P wherever you have wired internet devices.
  • High speeds and long range
    Using advanced Home Plug AV technology, TL-PA4022P KIT provides stable, ultra-high-speed data transmissions for long ranges. TL-PA4022P KIT easily handles bandwidth intensive applications. Stream in HD, game online and download large files without interruption thanks to reliable powerline links.
  • Power socket for additional devices
    With its integrated power socket, the TL-PA4022P KIT provides ultimate convenience for your home. Connect an additional device or power strip to the adapter as though it were a normal wall socket.
  • Two LAN ports
    TL-PA4022P KIT is equipped with an additional LAN port to give you more wired network connections. Link two devices to the adaptor via Ethernet cables to enjoy fast, simultaneous wired internet on both.
  • Saves power
    TL-PA4022P KIT automatically switches from its regular working mode to efficient Power-Saving mode when not in use.
TP-Link TL-PA4022P KIT AV600 2-port Passthrough Powerline - Starter Kit - powerline adapter kit - wall-pluggable
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
600 Mbps
Integrated power socket
IEEE 802.3, IEEE 802.3u, HomePlug AV, IEEE 1901
5.8 cm x 4.2 cm x 9.5 cm
Linux, Apple MacOS X 10.7 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1, Windows 10
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
600 Mbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, IEEE 1901, FCC, RoHS
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV - power , LAN: 2 x 10Base-T/100Base-TX - RJ-45
Internal power supply
2.93 Watt
TP-Link TL-PA4010P Powerline Adapter
2 x network cable - 2 m
Software Included
Drivers & Utilities
5.8 cm
4.2 cm
9.5 cm
10 - 90% (non-condensing)
Speed: 600Mbps
Connectivity: Wired
Brand: TP LINK
