TP LINK AV600 Nano Powerline Adapter Starter Kit
Quicklinx: CMB8WS00 Mfr#: TL-PA4010KIT V1.20
Type: Powerline adapter kit
Speed: 600Mbps
Connectivity: Wired
Pass-through Socket: [N/A]
24 left in stock
£30.42 ex VAT
£36.50 inc VAT
Using advanced Home Plug AV technology, TL-PA4010KIT provides users with stable, high-speed data transfer rates of up to 600 Mbps on a line length of up to 300 meters. With speed of up to 600 Mbps, TL-PA4010KIT enables heavy-bandwidth applications like HD streaming, on-line gaming and large file downloading, turning your home into a robust and high-speed networking.
With its ultra-compact housing design, TL-PA4010KIT is much smaller than TP-LINK's legacy mini 600 Mbps powerline products. At just 28.5 mm thick, it nearly blends completely in front of any power outlet.
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
  • Up to 600 Mbps powerline speeds ideal for HD streaming
  • Miniature design
  • Pair button for easy network security
TP-Link TL-PA4010 KIT V1.20 Starter Kit - powerline adapter kit - wall-pluggable
Kit Content
2 x TL-PA4010 powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
600 Mbps
Power-saving mode, pair button
IEEE 802.3, IEEE 802.3u, HomePlug AV
6.5 cm x 5.2 cm x 2.85 cm
Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
Kit Content
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
600 Mbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, FCC, RoHS
Status Indicators
Power, LAN, powerline
Line Properties
Line Coding Format
OFDM
LAN: 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
2 Watt
2 x network cable
6.5 cm
5.2 cm
2.85 cm
10 - 90% (non-condensing)
Speed: 600Mbps
Connectivity: Wired
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
