TP LINK AV600 300Mbps Wireless N Powerline Adapter Kit
Quicklinx: CMBGWS00 Mfr#: TL-WPA4220KIT V1.20
Type: Bridge
Speed: 500Mbps
Connectivity: Wireless, Wired
Pass-through Socket: No
  • IEEE 802.11n
Hurry, only 1 left in stock!
£42.92 ex VAT
£51.50 inc VAT
P-LINK's TL-WPA4220KIT extends your Internet connection to every room of the house through your home's existing electrical circuitry. The TL-WPA4220 features a Wi-Fi clone button enabling super range extension, which means it can automatically copy the SSID and password of your router. In this way, TL-WPA4220 simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
  • One touch super range extension
    With a Wi-Fi clone button enabling super range extension, the TL-WPA4220 can automatically copy the wireless network name (SSID) and password of your router at the push of a button. After pressing the button, you can place the powerline adapter anywhere you want wired or wireless access and enjoy seamless networking across your entire home or office.
  • 500 Mbps - ideal for HD video streaming
    With advanced HomePlug AV technology, TL-WPA4220KIT provides you with stable, high-speed data transfer rates of 500 Mbps on a line length of 300 meters. It is a great choice for a whole home solution to connect all network compatible devices - from computers, game consoles to set-top boxes for IPTV to printers and NAS hard drives.
  • Extend WiFi coverage to every room
    With wireless speeds of 300 Mbps, you can effortlessly extend your WiFi network via the existing powerline and broadcast a wireless signal to share with all your Wi-Fi enabled devices in another area of your home or office.
  • Plug and Play
    You can set up a hassle-free powerline network within minutes with TP-LINK's powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
TP-Link TL-WPA4220KIT AV500 WiFi Powerline Extender - V1.2 - Starter Kit - bridge - Wi-Fi - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
9.4 cm x 5.4 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Data Transfer Rate
500 Mbps
Encryption Algorithm
WPA, WPA2, WPA-PSK, 128-bit AES, WPA2-PSK, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
Status Indicators
Power, WLAN, LAN, link/activity
Line Properties
Line Coding Format
OFDM
LAN: 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
Internal power supply
6 Watt
TP-Link AV500 Nano Powerline Adapter (TL-PA4010)
1 x network cable - 2 m
Software Included
Drivers & Utilities
9.4 cm
5.4 cm
4 cm
10 - 90% (non-condensing)
Type: Bridge
Speed: 500Mbps
Connectivity: Wired
Brand: TP LINK
