TP LINK AV1300 Passthrough Powerline Kit
Quicklinx: FTNCWS00 Mfr#: TL-PA8033P KIT
Type: Powerline adapter kit
Speed: 1300Mbps
Connectivity: Wired
Pass-through Socket: Yes
Hurry, only 1 left in stock!
£66.75 ex VAT
£80.10 inc VAT
AV1300 3-port Gigabit Pass-through Powerline Starter Kit brings internet to any area with a power outlet using your home's electrical wiring.
  • HomePlug AV2 standard compliant
    The HomePlug AV2 standard creates high-speed data transfer rates of up to 1300Mbps to support all your online activities.
  • Gigabit Ethernet for fast connections
    Gigabit Ethernet port provides reliable high-speed wired connections for game consoles, smart TVs, STB and more.
  • 2 x 2 MIMO for more throughput over powerline
    2 x 2 MIMO technology is like adding an extra lane on a highway. It establishes multiple simultaneous connections so you can enjoy 2x speeds and greater stability.
  • Internet from any outlet
TP-Link AV1300 - Gigabit Passthrough Starter Kit - powerline adapter kit - wall-pluggable
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1300 Mbps
Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
13.1 cm x 7.1 cm x 4.2 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Europe
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1300 Mbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, Plug and Play, RoHS
Status Indicators
Power, LAN, powerline
Line Properties
Line Coding Format
OFDM
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
Internal power supply
5.53 Watt
2 x network cable
Europe
Software Included
Drivers & Utilities
13.1 cm
7.1 cm
4.2 cm
10 - 90% (non-condensing)
Speed: 1300Mbps
Connectivity: Wired
Brand: TP LINK
