Using your home's existing electrical circuit, TP-LINK's TL-PA8010P KIT AV1200 Gigabit Passthrough Powerline Starter Kit turns any electrical socket into an Internet connection. Simply plug into your wall socket and you are ready to enjoy HD streaming and gaming, no configuration required. You also won't lose a socket with its integrated pass through socket included! With speeds of 1200 Mbps for smooth Ultra HD streaming, online gaming or faster downloads, TL-PA8010P KIT is a perfect home entertainment companion.
1200 Mbps, perfect for bandwidth demanding activities
With its advanced HomePlug AV2 technology, TL-PA8010P KIT is introducing a powerline generation for even faster data transmission in the home network. TL-PA8010P KIT supports 2 x 2 MIMO with beamforming, so users benefit from ultra-fast data transfer speeds of 1200 Mbps. Perfect for bandwidth demanding activities like streaming ultra HD video to multiple devices simultaneously, online gaming and large file transfers. -
Gigabit Ethernet port for HD video streaming
Equipped with one gigabit Ethernet port, TL-PA8010P KIT allows users to connect a bandwidth intensive device in a room and ensures the smooth transmission of multiple HD video streaming. -
Extra power socket for additional devices
Where sockets are at a premium, the TL-PA8010P KIT with an integrated AC pass-through power socket, means the powerlines can be used like a traditional electrical socket. Plug your smart TV or games consoles into the powerlines, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting powerline performance.
- TP-Link TL-PA8010P KIT - v2 - Starter Kit - powerline adapter kit - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
- Data Transfer Rate
- 1.3 Gbps
- 2T2R MIMO technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, IEEE 1901
- Power
- AC 220 V (50 Hz)
- 13.1 cm x 7.1 cm x 4.2 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
- Localisation
- United Kingdom
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 1.3 Gbps
- Max Range Indoors
- 300 m
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, IEEE 1901, Plug and Play, RoHS
- Status Indicators
- Power, link/activity
Line Properties
- Line Coding Format
- OFDM
- 1 x HomePlug AV 2.0 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 220 V (50 Hz)
- 4.9 Watt
- Cables Included
- 1 x network cable - 2 m
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 13.1 cm
- 7.1 cm
- 4.2 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
F9DS 051124 Condition: Customer return - item has been used and shows signs of use, original packaging destroyed |
£37.69 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
