TP LINK AV1000 Powerline Starter Kit
Quicklinx: FTN8WS00 Mfr#: TL-PA7017 KIT
Using advanced technology, TL-PA7017 KIT ensures stable and high-speed wired connection, providing faster data transmissions. Stream in HD, game online and download large files without interruption.
  • Gigabit port for maximum connectivity
    With one Gigabit Ethernet port, TL-PA7017 KIT allows users to connect a bandwidth intensive device to the Internet at high speeds and ensures the smooth transmission of Ultra HD video streaming. This makes the TL-PA7017 KIT the perfect home entertainment companion.
  • No configuration required
    Connect a powerline adapter to the router, plug another powerline adapter into a wall socket in another room, and you're done.
  • Reduce power consumption
    TL-PA7017 KIT with its practical design and sophisticated power-saving mode, will automatically switch from its regular "working" mode to "power-saving" mode reducing its energy consumption.
TP-Link TL-PA7017 KIT - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
6.5 cm x 5.2 cm x 2.85 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1 Gbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, RoHS
Status Indicators
Power, LAN
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV 2.0 , LAN: RJ-45
Internal power supply
1 x network cable - 2 m
6.5 cm
5.2 cm
2.85 cm
10 - 90% (non-condensing)
