TP LINK AV1000 2port Gigabit Starter Kit
Quicklinx: CMBJWS00 Mfr#: TL-PA7020KIT
Comes with advanced HomePlug AV2 technology, TL-PA7020 KIT provides users with high-speed data transfer rates of up to 1000 Mbps, which is ideal for bandwidth intensive applications such as multiple HD/3D/4K video streaming, online gaming and large file transfers.
With 2 gigabit Ethernet ports, TL-PA7020 KIT can simultaneously connect up to 2 wired-only devices. This makes the TL-PA7020 KIT the perfect home entertainment companion. Connect any 2 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go!
Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you're done!
  • Ideal for slick streaming and smooth downloads
  • 2 gigabit ports for maximum connectivity
  • Plug-and-Play, no configuration required
  • Reduce power consumption by up to 85%
    TTL-PA7020 KIT, a new-generation of powerline adapter, with its practical design and sophisticated Power-Saving mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%.
TP-Link TL-PA7020 KIT - Starter Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
Data Transfer Rate
1 Gbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Quality of Service (QoS), Type of Service (ToS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
AC 230V (50 Hz)
12.3 cm x 6.8 cm x 3 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1
United Kingdom
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1 Gbps
Routing Protocol
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, Plug and Play, RoHS
Status Indicators
Power, LAN
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV 2.0 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
5.7 Watt
1 x network cable - 2 m
United Kingdom
12.3 cm
6.8 cm
3 cm
10 - 90% (non-condensing)
