TP Link Archer VR400 V3 Wireless Router - DSL modem - 802.11a/b/g/n/ac - Desktop
Quicklinx: G6WGWS00 Mfr#: ARCHER VR400 V3.0
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: IEEE 802.11g, Ethernet, IEEE 802.11a, IEEE 802.11b + 4 more
Speed: 1.2Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
£51.86 ex VAT
£62.23 inc VAT
The Archer VR400 unlocks the full potential of your Internet connection by providing combined dual band Wi-Fi speeds of up to 1.2 Gbps, including 300 Mbps on the 2.4 GHz band and 867 Mbps on the 5 GHz band, eliminating lag and buffering from your online experience. Two dedicated Wi-Fi networks support more devices and reduce wireless interference to create stable connections.
  • Superfast Wi-Fi up to 1.2 Gbps
    Archer VR400 unlocks the full potential of your Internet connection by providing combined dual-band Wi-Fi speeds of up to 1.2 Gbps, including 867 Mbps on the 5 GHz band and 300 Mbps on the 2.4 GHz band, eliminating lag and buffering from your online activities. Two dedicated Wi-Fi networks support more devices and reduce wireless interference to create stable connections.
  • High-speed VDSL modem router
    Advanced VDSL2 technology allows Archer VR400 to deliver impressive VDSL broadband speeds of up to 100 Mbps - faster than ADSL2+. Archer VR400 serves as a DSL modem and wireless router, combining two devices in one.
  • Versatile backup connectivity
    With multiple ports, Archer VR400 provides you with a variety of options when connecting to the Internet. As a backup, the LAN/WAN port allows Archer VR400 to accept connections from cable and fiber modems via an Ethernet cable. Additionally, the USB port supports 3G/4G dongle connections.
  • Superior range and stability
    Two high-performance external antennas help Archer VR400 create an expansive home network. Advanced Beamforming technology automatically locates wireless devices and forms targeted, highly efficient wireless connections.
  • MU-MIMO for higher efficiency
    MU-MIMO technology serves multiple devices at once, reducing wait time, increasing Wi-Fi throughput for every device, and making each stream more efficient
  • Blazing fast wired performance
    To help your wired devices achieve peak performance, the router's Gigabit Ethernet ports operate 10x faster than standard Ethernet. Full Gigabit ports provide rapid, reliable wired connections to computers, TVs, and game consoles.
TP-Link Archer VR400 - v3 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, DHCP, DNS, DDNS
Routing Protocol
RIP-1, IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
Firewall protection, DMZ port, NAT support, VPN support, DoS attack prevention, ALG support, manageable, print server, MAC address filtering, IPv6 support, WDS support, URL filtering, parental control, IP address filtering, WMM support, ACL support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, IPv4 support, port triggering, DHCP relay, Traffic Control, IP-MAC binding, DNS relay, DHCP client, SYN Flooding, Ping of Death, MU-MIMO technology, beamforming technology, port mapping, DynDNS, WPS button, OneMesh support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
DC 12 V 1 A
21.56 cm x 12.46 cm x 3.16 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/10
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS, RCM
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.993.2, ITU G.995.1, ITU G.998.4, ITU G.993.5
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Phone line: 1 x VDSL / ADSL2+ - RJ-11
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
External power adapter
DC 12 V
Electric Current Required
1 A
ADSL splitter
1 x network cable , 1 x phone cable
21.56 cm
12.46 cm
3.16 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Speed: 1.2Gbps
Brand: TP LINK
