TP LINK Archer VR2600 Wireless Gigabit VDSL/ADSL Modem Router
Quicklinx: CM9QWS00 Mfr#: Archer VR2600
  • IEEE 802.11n
With MU-MIMO technology, the Archer VR2600 is able to serve multiple connected devices simultaneously. To achieve amazing Wi-Fi speeds the Archer VR2600 uses astonishing 4-Stream technology to boost its wireless capabilities. The advanced VDSL2 technology allows the Archer VR2600 to deliver impressive VDSL broadband speeds.
With multiple inputs, the Archer VR2600 provides you with a variety of options when connecting to the Internet. You can connect external drives to the ports and easily share files, photos, music, and video across your network. To help your wired devices achieve peak performance, the router is also equipped with four Gigabit Ethernet ports that can operate much faster than standard Ethernet.
  • A giant leap in wireless world
    With MU-MIMO technology, the Archer VR2600 is able to serve multiple connected devices simultaneously. It dramatically reduces wait time for all clients by making better use of the unoccupied wireless capacity. This results Wi-Fi that is significantly faster on each device.
  • Exceptional Wi-Fi speed
    To achieve amazing Wi-Fi speeds on both the 2.4 GHz and 5 GHz bands, the Archer VR2600 uses astonishing 4-Stream technology to boost its wireless capabilities. The 800Mbps + 1733 Mbps dual-band Wi-Fi is capable of performing even very demanding bandwidth-intensive tasks with ease.
  • Superfast VDSL broadband
    The advanced VDSL2 technology allows the Archer VR2600 to deliver impressive VDSL broadband speeds. The Archer VR2600 serves as a DSL modem and wireless router, combining two devices in one. The integrated DSL port supports all standard DSL connections, including VDSL2, ADSL2+, and ADSL.
  • Versatile connectivity
    With multiple inputs, the Archer VR2600 provides you with a variety of options when connecting to the Internet. As a backup, both of the two USB ports support 3G/4G dongle connections. Additionally, the WAN port allows the Archer VR2600 to accept connections from cable and fiber modems via Ethernet cable.
  • Greatly enhanced processing
    A preeminent 1.4 GHz dual-core processor brings an ultimate level of performance and efficiency to Archer VR2600, making it possible for everyone in your crowded network to surf, stream, and game at once without any slowing down.
  • Superior Wi-Fi coverage
    Four high-performance external antennas help the Archer VR2600 create a strong, far-reaching network for your home. Beamforming technology further improves the router's coverage by helping it locate wireless devices to form stronger, more reliable connections, even with mobile devices moving from room to room.
  • Lightning-fast wired connection
    The Archer VR2600's dual USB 3.0 ports run significantly faster than USB 2.0 for data transfer at lightning speed. You can connect external drives to the ports and easily share files, photos, music, and video across your network. To help your wired devices achieve peak performance, the router is also equipped with four Gigabit Ethernet ports that can operate much faster than standard Ethernet.
TP-Link Archer VR2600 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, DHCP, DNS, DDNS
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
Firewall protection, DMZ port, NAT support, VPN support, ALG support, dynamic DNS server, manageable, print server, MAC address filtering, IPv6 support, WDS support, URL filtering, parental control, IP address filtering, WMM support, QoS, built-in DECT phone base station, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, IPv4 support, port triggering, DHCP relay, Traffic Control, IP-MAC binding, DNS relay, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
26.4 cm x 19.8 cm x 3.7 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.993.2, ITU G.995.1
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable , 1 x phone cable , 1 x phone splitter
Software Included
Drivers & Utilities
26.4 cm
19.8 cm
3.7 cm
10 - 90% (non-condensing)
