TP LINK Archer VR2100 AC2100 Wi-Fi VDSL/ADSL Modem Router
Quicklinx: FT7LWS00 Mfr#: Archer VR2100
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: IEEE 802.11n, Ethernet, Fast Ethernet, IEEE 802.11a + 4 more
Speed: 1733Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£72.62 ex VAT
£87.14 inc VAT
The Archer VR2100 is built to connect you to the internet, no matter your situation. The Ethernet WAN port supports wired connection to cable or fiber modem, letting you take full charge of its wireless capabilities as a router. In case your internet goes down, attach a 3/4G adapter to USB 3.0 port to serve as a backup option so you can get back online in no time.
  • Enjoy the network at full speed
    The Archer VR2100 makes full use of its dual band Wi-Fi abilities, reaching speeds of up to 1773 Mbps on 5 GHz band and 300 Mbps on 2.4 GHz band. Enjoy a total speed of up to 2.1 Gbps to eliminate latency and buffering from your HD streams and lag from online games.
  • 4×4 MU-MIMO - efficient Wi-Fi for every device
    MU-MIMO technology serves up to four devices at once, reducing wait time, increasing Wi-Fi throughput for every device, and making each stream more efficient.
  • Supports TP-Link OneMesh for whole-home coverage
    Co-work with TP-Link OneMesh products, to provide a more flexible and cost-effective Mesh network with a single Wi-Fi name for seamless whole-home coverage.
  • Lightning-fast wired connections
    One USB 3.0 port provides data transfers up to 10× faster than a traditional USB 2.0 port. Connect external storage devices and share files, photos, and videos at high-speed. As well as 4 Gigabit LAN ports help wired devices achieve peak performance for HD streaming and gaming.
TP-Link Archer VR2100 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 1733 Mbps
IPSec VPN tunnels: 10
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, ICMP/IP, IPSec, DHCP, DDNS
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS, CLI, TR-069
NAT support, SPI, ALG support, parental control, firmware upgradable, ATM, QoS, WPS, port forwarding, reset button, port triggering, IP-MAC binding, DoS, SYN Flooding, Ping of Death, beamforming technology, 4x4 MU-MIMO technology, PPP
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
21.6 cm x 16.4 cm x 3.68 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1 / 10
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, RoHS, RCM
Status Indicators
Power, LAN, USB, WPS, Internet, DSL, 2.4/5 GHz
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.998.4, ITU G.993.5
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , Phone line: 1 x VDSL / ADSL2+ - RJ-11
Aerial
Aerial
External detachable and internal
Antenna Qty
4
External power adapter
ADSL splitter
1 x network cable , 1 x modem cable
21.6 cm
16.4 cm
3.68 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Speed: 1733Mbps
Brand: TP LINK
