TP LINK Archer TX3000E AX3000 Wi-Fi 6 Bluetooth 5.0 PCI Express Adapter
Quicklinx: FTN4WS00 Mfr#: Archer TX3000E
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11n, IEEE 802.11b, IEEE 802.11a + 3 more
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
  • IEEE 802.11n
£41.53 ex VAT
£49.83 inc VAT
The Wi-Fi 6 standard guarantees extreme speed, ultra-low latency, and uninterrupted connectivity. Utilizing the Wi-Fi 6 foundation, Archer TX3000E is designed to liberate your gaming from cables and fully optimize your gameplay. Discover the missing component of your gaming arsenal!
  • Stay immersive
    1024-QAM and a 160MHz bandwidth deliver powerful, continuous Wi-Fi to fully unlock the potential of your Wi-Fi 6 router. Achieving speeds 3x faster than standard AC Wi-Fi drives your PC to peak performance so your setup keeps pace with your jaw-dropping skills.
  • Incredibly smooth gameplay
    Lower latency is essential to gaming success. Revolutionary OFDMA reduces lag by up to 75%. Enjoy ultra-responsive real-time gaming or immersive VR experiences.
  • Broader coverage
    Two multidirectional and high-performance antennas with a magnetized base extend your existing Wi-Fi reception capabilities, allowing you to game anywhere and anytime. Place the magnetized antenna base anywhere on your desktop to find the optimal location for signal reception.
  • Simultaneous entertainment for all
    A revolutionary combination of OFDMA and MU-MIMO technologies ensures the most efficient Wi-Fi connection for your PC. OFDMA technology divides band resources into smaller units while MU-MIMO allows more devices to communicate simultaneously - without lag.
  • Bluetooth 5.0 compatible
    Archer TX3000E is compatible with the Bluetooth 5.0 technology, achieving 2x faster speed and 4x broader coverage than Bluetooth 4.2. Connect as many devices as you want, including game controllers, headphones, and keyboards, to enjoy a smoother experience than ever before.
  • Advanced security
    WPA3 provides more secure and individualized encryption in personal password safety, protecting your network from wireless hacking. Always keep your network safe while gaming online.
TP-Link Archer TX3000E - network adapter - PCIe
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
9.52 cm x 12.08 cm x 2.15 cm
Wi-Fi 5, Bluetooth 5.0, 802.11ax
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac, Bluetooth 4.2, Bluetooth 5.0, IEEE 802.11ax
Windows 10 64-bit Edition
Network adapter
Plug-in card
PCI Express x1
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0, 802.11ax
Performance
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM, 1024 QAM
Frequency Band
2.4 GHz, 5 GHz
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
5 dBi
2 x aerial
Low-profile bracket, aerial base
1 x antenna cable - 1 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA3
FCC, RoHS
Software Included
Drivers & Utilities
9.52 cm
12.08 cm
2.15 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11a
Protocol: 802.11ax
Protocol: IEEE 802.11ac
Protocol: Bluetooth 5.0
Brand: TP LINK
