Archer T5E is an 802.11ac dual-band Wi-Fi PCI Express adapter with speeds up to 1167 Mbps (867 Mbps on the 5 GHz band and 300 Mbps on the 2.4 GHz band), providing Wi-Fi signals on two separate bands for all your online needs. Choose the 2.4 GHz band for surfing, emailing, and social media, or switch to 5 GHz band for gaming, streaming, and large file downloads.
Arm your PC with Bluetooth 4.2
Archer T5E is compatible with advanced Bluetooth 4.2 technology, achieving 2.5× faster speed and 10× more packet capacity than Bluetooth 4.0 to turn non-Bluetooth PCs into Bluetooth-?apable. Just connect your Bluetooth devices to your computer and enjoy. -
Powerful antennas for broader coverage
Two powerful signal-boosting high-gain antennas greatly extend your existing Wi-Fi reception capabilities, allowing you to enjoy fast and uninterrupted 4K streaming and smooth gaming.
- TP-Link Archer T5E - network adapter - PCIe
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- 2.15 cm x 12.08 cm x 8.32 cm
- Data Link Protocol
- Bluetooth 4.0, Wi-Fi 5, Bluetooth 4.2
- Data Transfer Rate
- 1167 Mbps
- Performance
- Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac, Bluetooth 4.2
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- Network adapter
- Form Factor
- Plug-in card
- PCI Express
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac, Bluetooth 4.2
- 1167 Mbps
- Performance
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz, 5 GHz
- 2T2R MIMO technology
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 2 x aerial
- Included Accessories
- Low-profile bracket, full-height bracket
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WEP, WPA2-EAP
- FCC, RoHS
- OS Required
- 2.15 cm
- 12.08 cm
- 8.32 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
