TP LINK Archer T5E AC1200 Wi-Fi Bluetooth 4.2 PCI Express Adapter
Quicklinx: FT7VWS00 Mfr#: Archer T5E
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11g, IEEE 802.11b + 3 more
Form Factor: Plug-in card
Type: Network adapter
  • IEEE 802.11n
  • Bluetooth 4.0
£37.51 ex VAT
£45.01 inc VAT
Archer T5E is an 802.11ac dual-band Wi-Fi PCI Express adapter with speeds up to 1167 Mbps (867 Mbps on the 5 GHz band and 300 Mbps on the 2.4 GHz band), providing Wi-Fi signals on two separate bands for all your online needs. Choose the 2.4 GHz band for surfing, emailing, and social media, or switch to 5 GHz band for gaming, streaming, and large file downloads.
  • Arm your PC with Bluetooth 4.2
    Archer T5E is compatible with advanced Bluetooth 4.2 technology, achieving 2.5× faster speed and 10× more packet capacity than Bluetooth 4.0 to turn non-Bluetooth PCs into Bluetooth-?apable. Just connect your Bluetooth devices to your computer and enjoy.
  • Powerful antennas for broader coverage
    Two powerful signal-boosting high-gain antennas greatly extend your existing Wi-Fi reception capabilities, allowing you to enjoy fast and uninterrupted 4K streaming and smooth gaming.
TP-Link Archer T5E - network adapter - PCIe
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
2.15 cm x 12.08 cm x 8.32 cm
Bluetooth 4.0, Wi-Fi 5, Bluetooth 4.2
Data Transfer Rate
1167 Mbps
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac, Bluetooth 4.2
Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Network adapter
Plug-in card
PCI Express
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac, Bluetooth 4.2
Data Transfer Rate
1167 Mbps
Performance
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
2T2R MIMO technology
Aerial
Antenna
External detachable
Antenna Qty
2
2 x aerial
Low-profile bracket, full-height bracket
Encryption Algorithm
WPA, WPA2, WPA-PSK, WEP, WPA2-EAP
FCC, RoHS
2.15 cm
12.08 cm
8.32 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Protocol: Bluetooth 4.2
Protocol: Bluetooth 4.0
Protocol: IEEE 802.11ac
Brand: TP LINK
