TP LINK Archer T4E - Network Adapter - PCIe
Quicklinx: F7DFWS00 Mfr#: ARCHER T4E(EU)
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
  • IEEE 802.11n
40 In Stock
£20.46 ex VAT
£24.55 inc VAT
Archer T4E supports the advanced Wi-Fi standard of IEEE 802.11ac, offering faster transferring rates. You can send emails and browse the web with 2.4 GHz network, while keeping the speedy 5 GHz band free for gaming, HD streaming and other bandwidth intensive applications.
  • Greater coverage with beamforming
    Beamforming technology smartly focuses Wi-Fi signals towards connected devices for stable connections and boosted range.
  • Ultimate stability
    A heat sink helps to dissipate the thermal energy generated by the adapter, which in turn improves stability. Additionally, lower temperatures help to extend the product lifespan.
  • External antennas for targeted signal
    Two external antennas utilize advanced wireless technology to achieve stable connections and boosted coverage.
TP-Link Archer T4E - network adapter - PCIe
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
11.52 cm x 12.08 cm x 2.15 cm
Europe
Wi-Fi 5
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits), Windows 10 (32/64 bits)
Network adapter
PCI Express
Europe
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Performance
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
2T2R MIMO technology, beamforming technology
Aerial
Antenna
External detachable
Antenna Qty
2
2 x aerial
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
11.52 cm
12.08 cm
2.15 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Brand: TP LINK
