TP LINK Archer T3U AC1300 Mini Wireless MU-MIMO USB Adapter
Quicklinx: FT7RWS00 Mfr#: Archer T3U
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11g, IEEE 802.11b, IEEE 802.11n + 1 more
Form Factor: External
Compatibility: [N/A]
Type: Network adapter
  • IEEE 802.11n
18 In Stock
£17.29 ex VAT
£20.74 inc VAT
Wireless AC technology means Archer T3U delivers connections that are up to 3x faster than with the previous Wireless N standard. High-speed Wi-Fi (up to 867Mbps over the 5GHz band and 400Mbps over the 2.4GHz band) means Archer T3U is able to support all your online activities, from HD video streaming to lag-free online gaming and web surfing.
Archer T3U has a smart design that is tinier than a usual USB adapter. Not only could it be inserted into any USB port, but is quite easy to carry, which is convenient for most usage scenarios.
  • High-speed dual band adapter for better connections
  • Miniature design - makes it easy to take
  • USB 3.0 for superior transfer speeds
    Experience blazing-fast data transfers of up to 4.8Gbps with USB 3.0 - the latest USB connectivity standard. USB 3.0 transfers data up to 10x faster than USB 2.0 and is also backwards compatible with USB 2.0. Combined with 802.11ac Wi-Fi, USB 3.0 makes Archer T3U ideal for HD streaming, online gaming and large file downloads.
  • Boosted throughput with MU-MIMO
    With MU-MIMO technology, Archer T3U can provide two simultaneous data streams, improving the throughput and efficiency of the entire network when working with a compatible MU-MIMO router.
TP-Link Archer T3U - network adapter - USB 3.0
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
4.05 cm x 1.972 cm x 1.029 cm
Wi-Fi 5
Data Transfer Rate
1.2 Gbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.9 - 10.13
Network adapter
External
SuperSpeed USB 3.0
Wireless
Data Transfer Rate
1.2 Gbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Ad-Hoc Mode, MU-MIMO technology
Aerial
Antenna
Internal
Directivity
Omni-directional
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
4.05 cm
1.972 cm
1.029 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Brand: TP LINK
