TP LINK Archer T2U Plus AC600 High Gain Wi-Fi Dual Band USB Adapter
Quicklinx: FT7SWS00 Mfr#: Archer T2U Plus
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11b, IEEE 802.11a, IEEE 802.11n + 1 more
Form Factor: External
Compatibility: [N/A]
Type: Network adapter
  • IEEE 802.11n
More than 50 In Stock
£12.19 ex VAT
£14.62 inc VAT
Archer T2U Plus has one 5dBi high-gain external antenna to ensure stronger signal transmission and reception. Enjoy a stable Wi-Fi connection throughout your home.
  • Increased range
  • Adjustable, multi-directional antenna
    Rotate and adjust the antenna in multi-direction to improve using experience and performance in different environments.
  • Easy setup
    A friendly user interface ensures simple installation.
  • Advanced security
    WPA/WPA2 encryption standards keep your wireless connection safe from intruders.
TP-Link Archer T2U Plus - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.8 cm x 5.78 cm x 17.34 cm
Wi-Fi 5
Performance
Maximum data rate (2.4 GHz): 200 Mbps , Maximum data rate (5 GHz): 433 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows XP/ 7 / 8 / 8.1 / 10, Apple MacOS X 10.9 - 10.13
Network adapter
External
USB 2.0
Wireless
Performance
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Ad-Hoc Mode
Aerial
Antenna
External integrated
Gain Level
5 dBi
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
FCC, RoHS
Software Included
Drivers & Utilities
1.8 cm
5.78 cm
17.34 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Brand: TP LINK
