TP LINK ARCHER T2U 600Mbps (433+150) Wireless Dual Band Adapter
Quicklinx: 9NHJWS00 Mfr#: ARCHER T2U
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11b + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
31 In Stock
£14.80 ex VAT
£17.76 inc VAT
802.11ac - The Next Generation of WiFi
TP-LINK's Archer T2U comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds. With 433Mbps wireless speeds over the crystal clear 5GHz band or 150Mbps over the 2.4GHz band, the Archer T2U is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
AC600 Wireless Speed
The 5GHz 433Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4GHz 150Mbps Wi-Fi for average use such as web surfing.
The Best of Both Bands
TP-LINK's Archer T2U is a dual band USB Adapter that provides selectable 5 GHz and 2.4 GHz bands for the latest standard and backward compatibility to existing Wi-Fi network. It gives users the ability to access crystal clear 5GHz connections to upgrade their notebook or PC's wireless capabilities, while ensuring that they can still access legacy 2.4GHz band wireless networks.
WPA / WPA2 Encryptions - Advanced Security
The T2U provides WPA/WPA2 encryptions created by the WI-FI Alliance, promoting interoperability and security for WLAN, which effectively and efficiently protects the wireless network.
Bundled Utility - Quick & Hassle-Free Installation
With its bundled wireless setup utility and WPS button, the T2U is very easy to setup and secure, even for novice users.
  • 802.11ac - the next generation of WiFi
    TP-LINK's Archer T2U comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds. With 433 Mbps wireless speeds over the crystal clear 5 GHz band or 150 Mbps over the 2.4 GHz band, the Archer T2U is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
  • AC600 wireless speed
    The 5 GHz 433 Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4 GHz 150 Mbps Wi-Fi for average use such as web surfing.
  • The best of both bands
    TP-LINK's Archer T2U is a dual band USB Adapter that provides selectable 5 GHz and 2.4 GHz bands for the latest standard and backward compatibility to existing Wi-Fi network. It gives users the ability to access crystal clear 5 GHz connections to upgrade their notebook or PC's wireless capabilities, while ensuring that they can still access legacy 2.4 GHz band wireless networks.
  • WPA/WPA2 encryptions - advanced security
TP-Link Archer T2U - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
4.1 cm x 1.95 cm x 0.87 cm
Wi-Fi 5
Data Transfer Rate
600 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
600 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Ad-Hoc Mode, WPS
Aerial
Antenna
Internal
Directivity
Omni-directional
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
4.1 cm
1.95 cm
0.87 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: TP LINK
