TP LINK Archer NX200 5G AX1800 Wireless Dual-Band Gigabit Router
Quicklinx: J1F1WS00 Mfr#: Archer NX200
26 In Stock
£190.84 ex VAT
£229.00 inc VAT
The TP-Link Archer NX200 V1 bridges and routers bring enhanced connectivity and security to your home network. This device is not just a router; it's a comprehensive solution for high-speed Internet, extensive coverage, and robust protection against cyber threats. With the integration of both 5G and Wi-Fi 6 technologies, users can enjoy faster speeds and reduced latency, making it ideal for streaming, gaming, and downloading. The Archer NX200 V1 is designed with security in mind, featuring WPA3 encryption and a suite of security features to keep your network safe. Managing your network is easier than ever with EasyMesh support, allowing for straightforward setup and network management. Additionally, the router's 10 internal antennas ensure your entire home is covered, providing reliable connections for all your devices. Whether you're looking for speed, security, or simplicity, the Archer NX200 V1 meets your needs.
  • Advanced connectivity
    With support for both 5G and Wi-Fi 6 technologies, the Archer NX200 V1 ensures your devices enjoy faster speeds and lower latency. Whether streaming, gaming, or downloading, experience enhanced wireless performance.
  • Comprehensive security
    Equipped with WPA3 encryption and a suite of security features including Access Control List (ACL) support, Stateful Packet Inspection (SPI), and DoS protection, this router provides a fortified barrier against cyber threats.
  • Effortless network management
    Featuring EasyMesh support and a user-friendly interface, setting up and managing your home network is simple. Parental controls and guest network capabilities offer additional layers of control and security.
  • Seamless coverage
    Boasting 10 internal antennas and features like Quality of Service (QoS) and Wi-Fi Multimedia (WMM) support, the Archer NX200 V1 delivers extensive coverage and ensures prioritization of traffic for critical applications.
  • Versatile connectivity options
    With three integrated LAN ports and support for a wide range of cellular bands, this router offers flexible connection options for a variety of network configurations and devices, ensuring you're always connected.
TP-Link Archer NX200 V1 - wireless router - Wi-Fi 6 - 5G - desktop
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
UMTS, FDD LTE, TDD LTE
Generation
5G
Cellular Band
LTE B3, LTE B7, LTE B20, LTE B1, LTE B5, LTE B28, LTE B8, LTE B40, LTE B41, LTE B38, LTE B32, LTE B42, LTE B43, 5G n78, 5G n1, 5G n3, 5G n5, 5G n7, 5G n8, 5G n20, 5G n28, 5G n40, 5G n41, 5G n77, 5G n38, UMTS B1, UMTS B5, UMTS B8
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
4.67 Gbps
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS, IPv4, IPv6, OpenVPN
Routing Protocol
Static IP routing
Remote Management Protocol
DHCP
SPI, ALG support, parental control, IP address filtering, firmware upgradable, WMM support, ACL support, QoS, virtual server support, WAN failover, DHCP server, port forwarding, reset button, port triggering, dynamic IP mode, DHCP client, Wireless Scheduler, domain filter, IPMB, DMZ support, WPS button, EasyMesh, Guest Network, Address Reservation, Wi-Fi on/off button, No-IP DDNS, DoS protection
IEEE 802.11, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax
AC 100-240 V (50/60 Hz) 0.6 A
9.9 cm x 9.9 cm x 19 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
4.67 Gbps
Performance
Routing Protocol
Static IP routing
DHCP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA3
Wi-Fi Rating
AX1800
IEEE 802.11, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Plug and Play, RoHS
Line Properties
Line Coding Format
1024 QAM
Communications
Generation
5G
Cellular Band
LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 2 x
Expansion Slots
1 (total) / 1 (free) x Nano-SIM
Aerial
Aerial
Internal
Antenna Qty
10
Configuration Details
8 internal LTE/5G antennas, 2 internal Wi-Fi aerials
External power adapter
Electric Current Required
0.6 A
1 x network cable , 1 x power adapter - 1.5 m
9.9 cm
9.9 cm
19 cm
10 - 90% (non-condensing)
Brand: TP LINK
