TP LINK Archer MR400 V3 Wireless Router WWAN 802.11a/b/g/n/ac Duel
Quicklinx: FH9GWS00 Mfr#: Archer MR400
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11g, Ethernet, Fast Ethernet, IEEE 802.11b + 3 more
Speed: 150Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£89.59 ex VAT
£107.50 inc VAT
Take full advantage of your cutting-edge 4G LTE network with the Archer MR400, which can achieve high download speeds. The Archer MR400 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
  • Plug and Play
    With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do is insert a micro SIM card and turn on the Router. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
  • Share your 4G LTE network
    Take full of advantage of your cutting-edge 4G LTE network for download speeds of up to 150 Mbps. Share your 4G LTE network with multiple Wi-Fi devices and enjoy uninterrupted HD movies, rapid file downloads, and smooth video chats. Fully compatible with FDD-LTE and TDD-LTE to work with most service providers worldwide.
  • Wi-Fi where you need it
    Enjoy unmatched convenience and versatility. Tested in the field for years to ensure universal compatibility with 2 advanced LTE antennas to deliver a smooth connection. Simply plug in a micro SIM card and power on this elegant piece of technology to utilize fast and stable Wi-Fi, whether you’re at home or working remote.
  • Internet access for up to 64 devices simultaneously
    Easily share a 3G/4G connection with up to 64 wireless devices, such as phones, tablets, and laptops, at the same time. 4 LAN ports stand ready to provide internet for wired devices like desktop computers.
TP-Link Archer MR400 v3 - wireless router - WWAN - Wi-Fi 5 - desktop
Wireless router - wireless cellular modem
Enclosure Type
Desktop
Mobile Communication Protocol
UMTS, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Concurrent devices: 64 , SSL VPN tunnels: 10
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
DoS attack prevention, manageable, IPv6 support, parental control, firmware upgradable, WMM support, file sharing, virtual server support, WPS, DHCP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, IP-MAC binding, on/off switches, DHCP client, WPA encryption, guest access, DMZ support, Advanced QoS, DynDNS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
20.2 cm x 14.1 cm x 3.36 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, Plug and Play, RoHS
Communications
Wireless cellular modem
Max Transfer Rate
150 Mbps
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , Antenna: 2 x
Expansion Slots
1 (total) / 1 (free) x Micro-SIM
Aerial
Aerial
External integrated and internal
External power adapter
1 x network cable
20.2 cm
14.1 cm
3.36 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Speed: 150Mbps
Brand: TP LINK
