TP LINK Archer MR200 AC750 Wireless Dual Band 4G LTE Router
Quicklinx: BPPBWS00 Mfr#: ARCHER MR200
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11a, IEEE 802.11b, Ethernet, Fast Ethernet + 3 more
Speed: 433Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
19 In Stock
£82.21 ex VAT
£98.65 inc VAT
Take full advantage of your cutting-edge 4G LTE network with the Archer MR200, which can achieve download speeds of up to 150 Mbps. The Archer MR200 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
The 4G LTE router creates a simultaneous dual band Wi-Fi network that can deliver data at speeds of up to 733 Mbps. The two distinct wireless networks, utilizing the 2.4 GHz and 5 GHz bands, provide optimized performance and minimize signal interference. The incorporation of advanced antennas and the latest wireless technology allows you to enjoy stable connections and incredible coverage.
With an integrated 4G LTE modem and a built-in Micro SIM card slot, all you need to do insert a Micro SIM card and turn on the Archer MR200. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
TP-Link Archer MR200 - wireless router - WWAN - Wi-Fi 5 - desktop
Wireless router - wireless cellular modem - 3-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
IPSec VPN tunnels: 10
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, CLI
Firewall protection, DHCP support, NAT support, NAPT support, IGMP snooping, SPI, MAC address filtering, VPN passthrough, WDS support, parental control, IP address filtering, firmware upgradable, QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
20.2 cm x 14.1 cm x 3.36 cm
Apple MacOS, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
Status Indicators
Port status, power, link/activity
Communications
Wireless cellular modem
Max Transfer Rate
150 Mbps
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
External power adapter
1 x network cable
Software Included
Drivers & Utilities
20.2 cm
14.1 cm
3.36 cm
10 - 90% (non-condensing)
BPPB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.09
Standards: IEEE 802.11b
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 433Mbps
Brand: TP LINK
