TP LINK Archer D5  AC1200 Wireless Dual Band Gigabit ADSL2+ Router
Quicklinx: 9J34WS00 Mfr#: Archer D5
  • IEEE 802.11n
Claim a FREE AC Wireless adapter with this purchase!
TP-LINK's Archer D5 AC1200 Wireless Dual Band Gigabit ADSL2+ Modem Router is a combined wired/wireless network connection device with integrated wireless router and ADSL modem, reducing hassle of configuration and saving space. Featuring a variety of features and rich functionality, Archer D5 is the perfect hub of your home or business network.
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer D5 comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause.
1.2Gbps Concurrent Dual Band - More Bandwidth, Less Interference
With 867Mbps wireless speeds over the crystal clear 5GHz band and 300Mbps over the 2.4GHz band, Archer D5 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
External Antennas and High Power Amplifiers - Fully Expanded Coverage
With detachable dual band external antennas combined with higher quality antenna technology, you can experience excellent wireless performance with high speed and stability. Furthermore, its high power amplifiers provide stronger signals in every direction with better coverage. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections - Ultrafast Data Transfer Speeds
With one Gigabit LAN/WAN port and 3 Gigabit LAN ports, the Archer D5 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
Dual Multifunctional USB Ports - Easy Storage and Sharing
Using the Archer D5's two multi-functional USB 2.0 ports, you can share a printer with multiple computers and devices on your network and can also share files & media at home or via the FTP server while away from home.
Interchangeable LAN/WAN Port - Versatile Connectivity
The Archer D5 supports ADSL or Ethernet WAN connections (EWAN), which allows users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
Easy Setup
Included in the resource CD, TP-LINK's optimized configuration utility can help you complete the entire software installation and wireless network settings in just a few minutes. it's worth mentioning that with built-in intelligent auto-detection, Archer D5 is capable of automatically figuring out which connection type to use in a flash, saving you the trouble of searching for your connection information type and speeding up the setup process.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
IPv6 Supported
Archer D5 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of new services and improved user experience.
  • 802.11ac - the next generation of Wi-Fi
  • 1.2 Gbps concurrent dual band - more bandwidth, less interference
    With 867 Mbps wireless speeds over the crystal clear 5 GHz band and 300 Mbps over the 2.4 GHz band, Archer D5 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4 GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5 GHz band - all at the same time.
  • External antennas and high power amplifiers - fully expanded coverage
  • Full Gigabit wired connections - ultra-fast data transfer speeds
  • Dual multifunctional USB ports - easy storage and sharing
  • Interchangeable LAN/WAN port - versatile connectivity
  • Easy setup
    Included in the resource CD, TP-LINK's optimized configuration utility can help you complete the entire software installation and wireless network settings in just a few minutes. It's worth mentioning that with built-in intelligent auto-detection, Archer D5 is capable of automatically figuring out which connection type to use in a flash, saving you the trouble of searching for your connection information type and speeding up the setup process.
  • Guest network
    Guest network access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
  • IPv6 supported
    Archer D5 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of services and improved user experience.
TP-Link ARCHER D5 AC1200 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 3-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
IPSec VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, DHCP
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
NAT support, DoS attack prevention, ALG support, dynamic DNS server, manageable, MAC address filtering, IPv6 support, WDS support, URL filtering, parental control, IP address filtering, WMM support, ACL support, QoS, WPS, IPSec passthrough, DHCP server, Samba support, FTP server, wireless bridge mode, reset button, IPv4 support, port triggering, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
22.9 cm x 16 cm x 3.7 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
PPTP, L2TP, DHCP
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
WAN: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
ADSL splitter
1 x network cable , 1 x phone cable
Software Included
Drivers & Utilities
22.9 cm
16 cm
3.7 cm
10 - 90% (non-condensing)
