TP LINK Archer D20 AC750 Dual Band Modem Router
Quicklinx: BLYJWS00 Mfr#: ARCHER D20
  • IEEE 802.11n
Coming with the next generation Wi-Fi standard - 802.1 lac, 3 times faster than wireless N speeds in a single stream, Archer D20 delivers a combined wireless data transfer rate of up to 750Mbps with 300Mbps over 2.4GHz and 433Mbps over 5GHz. 802.1 lac also brings higher power efficiency and robust security, making Archer D20 a perfect hub for your home or small office network.
  • Premium Wireless Network experience
    Simultaneous dual band offers the flexibility of two dedicated networks for basic tasks and bandwidth- intensive applications respectively. Two dual band external antennas deliver greater range and perfor-mance.5GHz2.4GHz
  • Easy USB storage and sharing
    Using the Archer D20's multi-functional USB 2.0 port, you can share a printer with multiple computers and devices on your network and can share files & media at home or via the FTP server while away from home.
  • Interchangeable LAN/WAN Port
    The Archer D20 supports ADSL or Ethernet WAN connections (EWAN), which allows users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
  • Guest Network
    Guest Network Access provides another secure Wi-Fi access for guests sharing your home or office network.
  • Parental Control
    Parental Controls allow parents or administrators to establish restricted access policies for children or staff.
  • IPv6 Supported
    The Archer D20 supports IPv6, the next generation of Internet protocol, helping you to future-proof your network.
  • Easy Network management - TP-LINK Tether
    TP-LINK Tether provides the easiest way to access and manage your router with your iOS or Android devices. From setup to parental control, Tether provides a simple, intuitive user interface to see what the status of your router is, who's online and what their privileges are. More models of the router can be configured with TP-LINK Tether.
  • Install and manage more easily
    TP-LINK's innovative web UI (User Interface) is designed into 3 different modules according to different user demands: Quick Setup, Basic and Advanced. The idea behind this is to ensure that everyone's home network installation and management experience is both quick & hassle free. This is evident in the fact that the web UI's basic setup can be completed within an astounding 15 seconds.
TP-Link Archer D20 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
IPSec VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, FTP, DHCP, DDNS
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
Firewall protection, DMZ port, NAT support, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, WDS support, URL filtering, parental control, IP address filtering, WMM support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, wireless bridge mode, bandwidth control, IPv4 support, port triggering, DHCP relay, DHCP client, DoS, SYN Flooding, Ping of Death
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
20.2 cm x 14.1 cm x 3.37 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
Status Indicators
Power, WLAN, link/activity, USB
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.995.1
Phone line: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
ADSL splitter
1 x network cable , 1 x phone cable
Software Included
Drivers & Utilities
20.2 cm
14.1 cm
3.37 cm
10 - 90% (non-condensing)
BLYJ C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
BLYJ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £18.89
