Super-Fast Transfer Speeds Providing a Superior WiFi Experience
Archer C9 comes with the next generation 11ac Wi-Fi standard, offering total data transfer speeds up to 1.9Gbps. With 1.3Gbps over the clearer 5GHz frequency, and 600Mbps using two wireless chips to maximize performance over the 2.4GHz frequency, your whole home will get excellent wireless coverage. Ultra-fast 1GHz dual-core CPU function as a great `heart' for fast, stable and responsive performance with Wi-Fi, Ethernet and USB devices. The outstanding Gigabit WiFi and Gigabit wired connections are ideal for bandwidth sensitive applications like streaming in HD and seamless online gaming. With Archer C9 you get a super-fast, high performance connected home.
Greater Coverage and Reliable Wi-Fi
Three dual band antennas and high-powered amplifiers ensure continuous Wi-Fi signal to all your devices while boosting widespread coverage throughout your home.
Beamforming Technology for Laser-Focused Wi-Fi
Beamforming concentrates the Wi-Fi signal towards your Wi-Fi devices, focusing the data transmission to where you need it the most. Superior Wi-Fi bandwidth utilization increases Wi-Fi range, delivering highly targeted and efficient Wi-Fi connections.
Dual USB Ports for Easy Sharing
With a USB 3.0 port and a USB 2.0 port, it's easy to share local printers, files and media within the network and between devices. Utilize the FTP server to access files stored on the router while away home. Take advantage of USB 3.0 with 10x faster speed than traditional USB 2.0.
Tether APP
TP-LINK Tether provides the easiest way to access and manage your router with your iOS devices.
Elegant Appearance
The sophisticated design enhances every home. Its gentle curves, excellent crafting and remarkable quality exudes style and elegance without compromising on excellent performance.
Super fast transfer speeds providing a superior Wi-Fi experience
Archer C9 comes with advanced Wi-Fi, offering lightning-fast data transfer speeds. With clearer frequency and higher performance, your whole home will get excellent wireless coverage. The outstanding Gigabit Wi-Fi and Gigabit wired connections are ideal for bandwidth-sensitive applications like streaming high-definition content and seamless online gaming. With Archer C9 you get a super-fast, high performance connected home. -
Greater coverage and reliable Wi-Fi
Three dual band antennas and high-powered amplifiers ensure continuous Wi-Fi signal to all your devices while boosting widespread coverage throughout your home. -
Dual USB ports for easy sharing
With a USB 3.0 port and a USB 2.0 port, it's easy to share local printers, files and media within the network and between devices. Utilize the FTP server to access files stored on the router while away home. Take advantage of USB 3.0 with much faster speed than traditional USB 2.0. -
Elegant appearance
The sophisticated design enhances every home. Its gentle curves, excellent crafting and remarkable quality exudes style and elegance without compromising on excellent performance. -
Guest Network feature
Guest Network Access provides secure access to guests sharing your Wi-Fi network. -
Parental Control tool
Parental Controls allow parents or administrators to deploy restricted access for children or staff. With URL blocking, you can easily set up a black or white list to limit the level of web access. -
Easy setup
Quick and hassle-free installation via the web configuration utility from any laptop, smartphone or tablet.
- TP-Link ARCHER C9 AC1900 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.9 Gbps
- Performance
- Maximum throughput (2.4 GHz): 600 Mbps , Maximum throughput (5 GHz): 1.3 Gbps
- PPTP, L2TP, IPSec, PPPoE, DNS, DDNS
- Firewall protection, DMZ port, NAT support, SPI, DoS attack prevention, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, WDS support, parental control, IP address filtering, domain blocking, WMM support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, static IP mode, wireless bridge mode, reset button, bandwidth control, IPv4 support, port triggering, dynamic IP mode, IP-MAC binding, DHCP client, DHCP reservation, Guest Zone support, beamforming technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 22.1 cm x 8.6 cm x 16.85 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8, Windows 8.1, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 10
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.9 Gbps
- Performance
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1900
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Processor
- 1 GHz
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 22.1 cm
- 8.6 cm
- 16.85 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
