TP LINK Archer C6 AC1200 Dual-Band Wi-Fi Router
Quicklinx: FT7HWS00 Mfr#: Archer C6
  • IEEE 802.11n
15 In Stock
£37.85 ex VAT
£45.42 inc VAT
The Archer C6 creates a reliable and blazing-fast network powered by 802.11ac Wi-Fi technology. The 2.4GHz band delivers speeds up to 300Mbps, ready for everyday tasks like emailing and web browsing, while the 5GHz band delivers speeds up to 867Mbps, ideal for HD video streaming and lag-free online gaming.
Four external antennas and one internal antenna send Wi-Fi signals to every corner of your home. Stay connected and enjoy fast Wi-Fi whether you are lounging on the sofa or on the balcony. With a powerful chipset, the Archer C6 provides ideal Wi-Fi coverage. The 2.4GHz band coverage is especially impressive, eliminating Wi-Fi dead-zones and beating that of other competing routers.
  • Smooth entertainment with AC1200 dual band Wi-Fi
  • 5 high-performance antennas Wi-Fi coverage throughout your home
  • It's an access point, too
    Switch the working mode of the Archer C6 to Access Point Mode to share your wired network with other wireless devices.
  • MU-MIMO matters increase speed, throughput, capacity
    MU-MIMO lets the Archer C6 serve multiple devices at once. No more bandwidth congestion or latency. All devices get their data faster and Wi-Fi is used more efficiently!
  • Gigabit connectivity, 10× faster
    With one Gigabit WAN port and four Gigabit LAN port, speeds can be up to 10× faster than standard Ethernet connections. Connect your favorite wired devices to the Archer C6 and get impressed!
  • Easy setup and management with the Tether APP
    The free Tether app is available for both Android and iOS devices, making it easy to set up the Archer C6 and manage your network settings.
TP-Link Archer C6 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP
Firewall protection, SPI, manageable, IPv6 support, parental control, Access Point operational mode, WMM support, WPS, DHCP server, static IP mode, port forwarding, reset button, IPv4 support, dynamic IP mode, IP-MAC binding, DHCP client, DoS, MU-MIMO technology, WDS bridge, DMZ support, black list, white list, DynDNS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
23 cm x 14.4 cm x 3.5 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1, Windows 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
4
Directivity
Omni-directional
External power adapter
1 x network cable
23 cm
14.4 cm
3.5 cm
Limited warranty - parts and labour - 2 years
10 - 90% (non-condensing)
Type: Wireless router
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Brand: TP LINK
