The Archer C58 features the advanced Wi-Fi standard - 802.11ac, widely compatible with both wireless AC and wireless N devices. With this excellent technology, the Archer C58 offers you faster, stronger and more capable Wi-Fi. Simply put: an amazing network experience on all your devices.
Lightning Wi-Fi powers perfect entertainment
The Archer C58 provides your entire home with simultaneous dual-band Wi-Fi connections. The strong and stable 2.4 GHz wireless band is perfect for sending emails, browsing the web or listening to music. Meanwhile, the 5 GHz wireless band provides great Wi-Fi speed for latency-sensitive entertainment so you can stream HD video, play online games and hold video chats all at the same time, without delay. -
Strong signal, great coverage
The Archer C58's three high-performance external antennas ensure full home Wi-Fi coverage. Combined with a dual-band wireless network, its increased stability and range means you will no longer suffer from weak, dropped connections. -
Easy parental control
Supervise children and staff with responsible access, controlled by parents or administrators. Use URL blocking to easily set up a black or white list and limit the level of web access. -
Guest network access
Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security.
- TP-Link Archer C58 AC1350 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.35 Gbps
- PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
- DoS attack prevention, print server, MAC address filtering, IPv6 support, WDS support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, DHCP client
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 22.5 cm x 14.8 cm x 3.3 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.35 Gbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1350
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Built-in Devices
- Led panel
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 3
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 22.5 cm
- 14.8 cm
- 3.3 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
