Archer C5400 delivers combined tri-band Wi-Fi speeds, establishing a network, that can connect more devices without slowing down. Smart Connect helps devices run even faster by assigning them to the channel to balance network demand.
Full technology empowers home entertainment
The router serves as a powerful entertainment hub for your home, that is capable of supporting multiple simultaneous HD video streams, online gaming, and other online activities without slowing down. Superior range and coverage keeps your devices connected, near or far. -
Maximized range and efficiency
The antennas with Beamforming technology detect the locations of your connected devices and concentrate wireless signal strength toward them. This makes all of your connections more efficient and stable, improving network performance, even in medium-sized offices and public cafes. -
Large file sharing
External hard drives can connect directly to the Archer C5400 via its USB 3.0 and 2.0 ports, making it easy to share large files, photos, music and video across your network. -
Smooth gaming and streaming
To help your wired devices achieve peak performance for smooth gaming and streaming, the Gigabit Ethernet ports operate faster.
- TP-Link Archer C5400 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Data Transfer Rate
- 5334 Mbps
- PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS, Bigpond
- Routing Protocol
- Static IP routing
- DoS attack prevention, print server, IPv6 support, VPN passthrough, antivirus analysis, parental control, IP address filtering, firmware upgradable, WMM support, ACL support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, IP-MAC binding, DHCP client, VPN Server, MU-MIMO technology, Tri-Band Smart Connect technology, Broadcom NitroQAM technology, domain filter, black list, white list
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 23 cm x 23 cm x 4.3 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8, Windows 8.1 / 10
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 5334 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC5400
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Processor
- 1.4 GHz
Line Properties
- Line Coding Format
- 1024 QAM
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External integrated
- Antenna Qty
- 8
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- OS Required
- 23 cm
- 23 cm
- 4.3 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
