Router
TP-LINK's Archer C2 comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause.
733Mbps Dual Band Connections for Lag-Free Work and Entertainment With 433Mbps wireless speeds over the crystal clear 5GHz band and 300Mbps over the 2.4GHz band, Archer C2 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
Stable Omnidirectional Signal and Superior Coverage With 2 detachable external antennas combined with higher quality antenna technology, you can experience excellent wireless performance with stable signal in every direction and high speed across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections for Ultrafast Data Transfer Speeds With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10× faster than fast Ethernet connections. The Archer C2 is a powerful hub to support a robust and extremely fast wired network.
Easy USB Storage and Sharing With the USB port, you can share a printer locally and files & media with networked devices or remotely via FTP server.
Guest Network Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
Parental Control Parental Control allows parents or administrators to establish restricted access policies for children or staff.
Easy Setup Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes.
IPv6 Supported Archer C2 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of new services and improved user experience.
Range Extender Boost Your Router Coverage to Expanded Dual Band WiFi RE200 expands your existing WiFi coverage with next generation 11AC WiFi technology. It works with any standard WiFi router and creates stronger dual band connections in hard-to-reach areas, allowing you to enjoy seamless wireless coverage throughout your home or office.
Next Generation 11AC WiFi Create faster access for 802.11 b/g/n and 802.11ac WiFi devices. RE200 delivers fast speeds of dual band WiFi up to 750Mbps and provides reliable connections for laptops, smartphones, tablets and other wireless-enabled devices. *Actual WiFi speeds may vary due to different user environments.
Enjoy Super Speeds in High Speed Mode With High-Speed technology, RE200 makes the best use of both WiFi bands to establish super speedy connections -- ideal for HD video streaming, online gaming and other bandwidth-intensive tasks. *In high speed mode, RE200 offers maximum performance but limits connection to one band (2.4GHz or 5GHz).
Easy Setup and Flexible Placement Press the WPS button on your router and the Range Extender button on your RE200 within 2 minutes to easily connect to the network. Once connected with an existing router, you can simply unplug and plug the RE200 back in anywhere within the wireless range of the existing router, without needing to configure the extender again. *The band used when connecting via the WPS buttons is sometimes indefinite and dependant on the settings on your router. If you want to establish a WPS connection in both 2.4GHz and 5GHz bands, please go to the RE200's web configuration page to configure this.
Entertainment Adapter The RE200's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
802.11ac
TP-Link's Archer C2 comes with the Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause. -
733 Mbps dual band connections for lag-free work and entertainment
With 433 Mbps wireless speeds over the crystal clear 5 GHz band and 300Mbps over the 2.4 GHz band, Archer C2 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4 GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5 GHz band - all at the same time. -
Stable omnidirectional signal and superior coverage
With 2 detachable external antennas combined with higher quality antenna technology, you can experience excellent wireless performance with stable signal in every direction and high speed across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office. -
Full gigabit wired connections for ultrafast data transfer speeds
With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10x faster than fast Ethernet connections. The Archer C2 is a powerful hub to support a robust and extremely fast wired network. -
Easy USB storage and sharing
With the USB port, you can share a printer locally and files & media with networked devices or remotely via FTP server. -
Guest network
Guest network access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data. -
Parental control
Parental control allows parents or administrators to establish restricted access policies for children or staff. -
Easy setup
Included in the resource CD, TP-Link's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes. -
IPv6 supported
Archer C2 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of services and improved user experience.
