TP LINK Archer C2  AC750 Wireless Dual Band Gigabit Router
Quicklinx: 9GBZWS00 Mfr#: Archer C2
  • IEEE 802.11n
Claim a FREE AC Wireless adapter with this purchase!
TP-LINK's Archer C2 comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause.
733Mbps Dual Band Connections for Lag-Free Work and Entertainment
With 433Mbps wireless speeds over the crystal clear 5GHz band and 300Mbps over the 2.4GHz band, Archer C2 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
Stable Omnidirectional Signal and Superior Coverage
With 2 detachable external antennas combined with higher quality antenna technology, you can experience excellent wireless performance with stable signal in every direction and high speed across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections for Ultrafast Data Transfer Speeds
With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10× faster than fast Ethernet connections. The Archer C2 is a powerful hub to support a robust and extremely fast wired network.
Easy USB Storage and Sharing
With the USB port, you can share a printer locally and files & media with networked devices or remotely via FTP server.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
Parental Control
Parental Control allows parents or administrators to establish restricted access policies for children or staff.
Easy Setup
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes.
IPv6 Supported
Archer C2 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of new services and improved user experience.
  • Concurrent dual band for lag-free work
    Simultaneous 2.4 GHz and 5 GHz offers you the flexibility of two dedicated networks - with multiple times the bandwidth for your needs. Simple tasks like sending e-mails or web browsing can be handled by the 2.4 GHz band while bandwidth-intensive tasks like online gaming or high-definition video streaming can be processed by the 5 GHz band - all at the same time.
  • Stable omnidirectional signal and superior coverage
  • Easy USB storage and sharing
    With the USB port, you can share files and media at home or via the FTP server while away from home and can also share a printer with multiple computers and devices on your network.
  • Full Gigabit wired connections
    With one Gigabit WAN port and four Gigabit LAN ports, speeds can be much faster than fast Ethernet connections. The Archer C2 is a powerful hub to support a robust and extremely fast wired network.
  • Guest Network Access
    Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network.
  • Parental Control
    Parental Control feature allows parents or administrators to establish restricted access policies for children or staff.
  • Easy setup
    Quick and hassle-free installation with optimized configuration utility.
TP-Link Archer C2 AC900 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Network / Transport Protocol
L2TP, PPPoE, PPTP, DHCP
Routing Protocol
Static IP routing
3T3R MIMO technology, WPS, WDS bridge, WMM support, IPv4 support, IPv6 support, DHCP client, DHCP server, DMZ port, domain filter, IP address filtering, IP-MAC binding, parental control, SPIF
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, UPnP
23 cm x 14.4 cm x 3.5 cm
Apple MacOS, Linux, UNIX, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, UPnP, RoHS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
23 cm
14.4 cm
3.5 cm
10 - 90% (non-condensing)
9GBZ C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
