TP LINK Archer AX12 V1 802.11a/b/g/n/ac/ax Wireless Router
Quicklinx: HJWGWS00 Mfr#: ARCHER AX12
Type: Wireless router
Connection Type: [N/A]
Standards: Ethernet, Fast Ethernet, IEEE 802.11b, Gigabit Ethernet + 5 more
Speed: 1.5Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
Hurry, only 3 left in stock!
£46.84 ex VAT
£56.20 inc VAT
  • Archer AX12 comes equipped with Wi-Fi 6 for faster speeds, greater capacity and reduced network congestion
  • Archer AX12 dual-band router reaches even faster speeds up to 1.5 Gbps (1201 Mbps on 5 GHz band and 300 Mbps on 2.4 GHz band)
  • Wi-Fi 6 technology communicates more data to more devices using revolutionary OFDMA and MU-MIMO technology while simultaneously reducing lag
  • Achieve strong and reliable Wi-Fi coverage with Archer AX12 as it focuses signal strength to your devices using Beamforming technology and four antennas
  • Target Wake Time technology reduces your devices' power consumption to extend their battery life
  • Set up your router in minutes with the powerful TP-Link Tether App
  • Gigabit Broadband internet access
    All gigabit Ethernet ports allow you to take full advantage of your broadband speed up to 1 Gbps. Plug your PCs, smart TVs, and game consoles into one of the three gigabit ethernet LAN ports for fast, reliable wired connections.
  • Wi-Fi coverage throughout your home
    4 high-performance external antennas boost Wi-Fi signals throughout your home. Beamforming technology detects devices and concentrates wireless signal strength towards them, especially for previously hard to reach outlets.
  • WPA3 level of cyber security
    WPA3 brings new capabilities to improve cybersecurity in personal networks. More secure encryption in Wi-Fi password safety and enhanced protection against brute-force attacks combine to safeguard your home Wi-Fi.
  • Easy setup and use
    Whether you prefer the intuitive Tether app or TP-Link's powerful web interface, you can set up your Archer AX12 in minutes. The Tether app allows you to manage network settings from any Android or iOS device.
  • Protect your children
    Block inappropriate content for your children, and customize a time range for better online habits.
  • Easy firmware upgrade
    Tired of upgrading firmware? OTA updates enable easy firmware upgrades with a click in the management panel. To keep your security and functions always up-to-date, just turn on the auto schedule.
TP-Link Archer AX12 V1 - wireless router - Wi-Fi 6 - desktop
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.5 Gbps
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Streams: 4
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6, OpenVPN
Routing Protocol
IGMP, static IP routing
Remote Management Protocol
HTTP, HTTPS, DHCP
IGMP snooping, URL filtering, parental control, Access Point operational mode, WMM support, ACL support, QoS, WPS, DHCP server, port forwarding, port triggering, SPIF, IP-MAC binding, DHCP client, FOTA, IGMP proxy, MU-MIMO technology, beamforming technology, router mode, Airtime Fairness, VLAN Tagging, PPTP server, OpenVPN server, IPTV support, Guest Network, Address Reservation, TWT, dynamic DNS, wireless radio enable/disable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
21.5 cm x 11.7 cm x 3.2 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10, Microsoft Windows 11
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.5 Gbps
Performance
Streams: 4
Routing Protocol
HTTP, HTTPS, DHCP
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WPA3-Personal
Wi-Fi Rating
AX1500
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, FCC, RoHS
Status Indicators
Power, Internet, 5 GHz, 2.4 GHz
Line Properties
Line Coding Format
1024 QAM, OFDMA
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
4
External power adapter
1 x network cable
21.5 cm
11.7 cm
3.2 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: 802.11ax
Standards: IEEE 802.11ac
Speed: 1.5Gbps
Brand: TP LINK
