TP LINK Archer AC4000 Tri-Band Wi-Fi Router
Quicklinx: FT7CWS00 Mfr#: Archer C4000
  • IEEE 802.11n
£143.69 ex VAT
£172.42 inc VAT
The Archer C4000 powers through every service, thread and application running on your network with a 1.8 GHz 64-bit quad-core CPU that delivers fast, lag-free connections to gaming, streaming and mobile devices.
  • Quad-core processing for powerful performance
  • Entertain every member at the same time
    Buffering will never be a problem from now on. With Tri-band and MU-MIMO Technology, the Archer C4000 wireless router can communicate with multiple devices at the same moment, sending and receiving data on the best available band. So you can still enjoy a non-stop MOBA or FPS game when your families are watching 4K videos online.
  • Far-reaching Wi-Fi coverage
    High-performance antennas with powered amplifier create strong Wi-Fi signal across your home. RangeBoost technology greatly improves ability to detect devices that are further away or low-powered, giving your network even greater coverage. Beam forming focuses on wireless signals towards connected devices for stable Wi-Fi.
  • Gigabit wired speeds and link aggregation
    All Gigabit Ethernet ports (1 WAN+ 4 LAN) bring wired speeds to the maximum. Plug your PCs, smart TVs and game consoles into one of the four Gigabit Ethernet ports for fast and reliable wired connections.
TP-Link Archer C4000 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Data Transfer Rate
4000 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS
VPN support, dynamic DNS server, print server, IPv6 support, parental control, WMM support, WPS, DHCP server, Samba support, FTP server, reset button, bandwidth control, IPv4 support, DHCP client, MU-MIMO technology, SmartConnect Technology, beamforming technology, Broadcom NitroQAM technology, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
20 cm x 20 cm x 3.9 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
4000 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC4000
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1.8 GHz
Line Properties
Line Coding Format
1024 QAM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
6
External power adapter
1 x network cable
20 cm
20 cm
3.9 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: IEEE 802.11ac
Speed: 4000Mbps
Brand: TP LINK
