TP LINK Archer AC2300 Dual-Band Wi-Fi Router
Quicklinx: FT7DWS00 Mfr#: Archer C2300
  • IEEE 802.11n
£128.66 ex VAT
£154.39 inc VAT
The Archer C3200 wireless router uses Tri-Band technology to run three separate Wi-Fi channels at once, creating a network that can connect to more devices without a trade-off in performance.
  • Maximum coverage and stability
    Six high-performance external antennas greatly increase the Archer C3200's range and signal stability. Beamforming technology further improves the router's Wi-Fi coverage by helping it locate wireless devices to form stronger, more reliable connections.
  • Run all your devices at once
    A powerful 1GHz dual-core CPU and three co-processors easily handle the demand made on the Archer C3200's network when multiple users are browsing, streaming, and gaming all at the same time.
  • Seamless streaming and gaming
    With the fastest combined Wi-Fi speed of up to 3200Mbps, the Archer C3200 lets you simultaneously game online and stream video in 4K Ultra HD across multiple devices without lag.
  • Lightning-fast wired performance
    External hard drives can connect directly to the Archer C3200 via its USB 3.0 and 2.0 ports, making it easy to share files, photos, music, and video across your network.
TP-Link Archer C2300 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2225 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
Dynamic DNS server, print server, MAC address filtering, IPv6 support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, IP-MAC binding, DHCP client, MU-MIMO technology, RangeBoost
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
21.6 cm x 16.4 cm x 3.68 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2225 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1.8 GHz
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
21.6 cm
16.4 cm
3.68 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 2225Mbps
Brand: TP LINK
