TP LINK Archer A7 AC1750 Dual-Band Wi-Fi Router
Quicklinx: FT7JWS00 Mfr#: Archer A7
  • IEEE 802.11n
£62.18 ex VAT
£74.61 inc VAT
Supports 802.11ac standard - 3 times faster than wireless N speeds
Simultaneous 2.4GHz 450 Mbps and 5GHz 1300 Mbps connections for 1.75Gbps of total available bandwidth
USB Port - easily shares files & media with networked devices or remotely via FTP server
Guest Network Access - provides secure Wi-Fi access for guests sharing your home or office network
Easy setup and management with Tether App
  • The WiFi standard for an advanced online experience
    The Archer A7 is a fast 802.11ac router with incredible range. It's better than many routers that are twice as expensive. This advanced WiFi is designed for high-traffic online activities and can help to run applications at triple the speed of the previous 802.11n standard.
  • Concurrent dual band connections for lag-free work and entertainment
    The Archer A7 operates both the 2.4GHz and 5GHz bands, ensuring amazing wireless performance. Simple tasks like sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
  • External WiFi greatly expand wireless coverage
    Three external antennas with advanced connection technology allow you to maintain impressive speeds. With antennas serving both the 2.4GHz and 5GHz band, you can enjoy incredible wireless coverage and reliability in any part of your large home or office.
  • Versatile USB connectivity
    A USB 2.0 port makes the Archer A7 a truly resourceful gateway. Share a hard drive full of media through your home network, or via an ftp server whenever you're away.
  • Full gigabit wired connections for ultrafast data transfer speeds
    With one Gigabit WAN port and four Gigabit LAN ports, speeds can be up to 10× faster than standard Ethernet connections. The Archer A7 is a powerful hub to support a robust and extremely fast wired network.
  • Parental controls
    Manage when and how connected devices can access the internet.
  • IPv6 supported
    Supports IPv6, the next generation of Internet protocol, helping you to future-proof your network.
  • Quality of service
    Prioritizes devices or applications to give faster performance where you need it.
TP-Link Archer A7 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, SPI, DoS attack prevention, dynamic DNS server, print server, MAC address filtering, IPv6 support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, Samba support, FTP server, reset button, bandwidth control, IPv4 support, port triggering, IP-MAC binding, DHCP client, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
24.3 cm x 16.06 cm x 3.25 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1750
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
Status Indicators
Port status, power, link/activity
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
External power adapter
1 x network cable
24.3 cm
16.06 cm
3.25 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11a
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11ac
Speed: 1.75Gbps
Brand: TP LINK
