TP LINK Archer A5 AC1200 Wireless Dual Band Router
Quicklinx: F9JTWS00 Mfr#: Archer A5
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11b, Ethernet, IEEE 802.11a, IEEE 802.11g + 3 more
Speed: 1200Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£21.94 ex VAT
£26.32 inc VAT
The Archer A5 lets your PC or laptop enjoy connections 3x faster than Wireless N with Wireless AC technology. With 300Mbps over the 2.4GHz band and 867Mbps over the crystal clear 5GHz band, the Archer A5 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
Four well-ordered antennas make all of your connections more efficient and stable. Advanced antenna technology increases the receiving sensitivity to enlarge Wi-Fi coverage for your home.
Supervise children and staff with responsible access, controlled by parents or administrators. Use key words to easily set up a black list and limit the level of web access.
Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security.
Captive portal helps maintain only authorized guests to use the network, presenting devices with a convenient, user-friendly authentication method to grant Wi-Fi access. Easily share your facebook account to anyone who connects to your network.
Set up the Archer A5 in minutes thanks to its intuitive web interface and the powerful Tether app. Tether also lets you manage its network settings from any Android or iOS device, including parental controls and access control.
  • High-speed dual band Wi-Fi for better connections
  • Innovative antenna design for maximum coverage
  • Easy parental control
  • Guest network access
  • Efficient guest authentication with Facebook
  • Easy setup and use
TP-Link Archer A5 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, reset button, bandwidth control, IPv4 support, port triggering, IP-MAC binding, DHCP client, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
22.987 cm x 14.419 cm x 3.685 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
Status Indicators
Port status, power, link/activity
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
4
Directivity
Omni-directional
External power adapter
1 x network cable
22.987 cm
14.419 cm
3.685 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 1200Mbps
Brand: TP LINK
