The Archer VR200 features super-fast broadband speeds of up to 100 Mbps and supports VDSL2. The modem router exploits the full potential of VDSL broadband connections to deliver Wi-Fi speeds of up to 750 Mbps. Also, by using two dedicated networks, it reduces wireless signal interference.
Versatile connectivity
The Archer VR200 is an integrated DSL modem router that works with any kind of Internet connection, including VDSL, VDSL2, ADSL, ADSL2, and ADSL2+. With the Gigabit Ethernet WAN possibility, the Archer VR200 can also be used with any fiber broadband or cable modem with an Ethernet output. -
Better coverage and a more stable connection
Three external antennas help the Archer VR200 provide stable coverage throughout your entire home and property. Advanced beamforming technology automatically locates wireless devices and forms targeted, highly efficient wireless connections. -
Fast USB sharing
With USB 2.0 ports, you can easily access and share a local printer, a local network drive, or a remote FTP server. Storing, accessing, and sharing files and media have never been easier. For added connection versatility, both USB ports support 3G/4G dongles, so you can stay connected without missing a beat. -
Gigabit wired connection
With four built-in Gigabit Ethernet ports, the Archer VR200 is capable of providing the stable, ultra-fast wired connections that you need to ensure lag-free gaming and uninterrupted HD video streaming. -
Elegant appearance
The sophisticated design enhances every home. Its gentle curves, excellent crafting and remarkable quality exudes style and elegance without compromising on performance. -
Easy setup and use
The Archer VR200's powerful web interface allows it to be set up and configured in a matter of minutes. The intuitive design allows users to easily monitor and personalize settings for a wide range of functions including guest networks and parental controls.
- TP-Link Archer VR200 - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+, VDSL2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 733 Mbps
- Capacity
- IPSec VPN tunnels: 10
- TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, DHCP, DNS, DDNS
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, CLI, TR-069
- Firewall protection, DMZ port, NAT support, VPN support, ALG support, dynamic DNS server, manageable, print server, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, reset button, IPv4 support, port triggering, DHCP relay, Traffic Control, IP-MAC binding, DNS relay, DHCP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 24.5 cm x 18.1 cm x 9 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 733 Mbps
- Capacity
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.993.2, ITU G.995.1
- LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , Phone line: 1 x VDSL / ADSL2+ - RJ-11
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable , 1 x phone cable
- Software Included
- Drivers & Utilities
- OS Required
- 24.5 cm
- 18.1 cm
- 9 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
